Fuel pressure gauge
Is it worth installing the perminent fuel gauge on the front fuel rail? I'm trying to resolve hard starting when hot. I replaced check valve, no smell of gas at dampers, regulator, temp sensor ok.
Formerly from Bannlist
I'm thinking you need to put your year of 928 in your signature somewhere. My first thought is accumulator, but not sure if your car has one or not.
As far as a permanent gauge, many will oppose it since it's just something that could fail and leak. In my opinion, I would put one. I likey gauges that give me instant information on the goings on in my mechanics.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior ![]() Porsche928Forums.com (NOW Mobile Enabled!) |
Sorry, I have the 86 with 32 valve.
I purchased one from Roger at 928s Rus for $52 (including shipping). Easy installation and a good way to eliminate one source of a problem in a no-start situation.
Mike
Mike 1982 Porsche 928 Auto Black on Black - Competition Package |
Trouble shooting guide from WSM.
69 911 2.3Ez 85 928S |
Thanks for the document. I saved and printed it.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 39K original miles, Goodyear F1 tires |
well i agree with mpdano..i like guages and intend on installing 2 fuel pressure guages(on in the car and one in the engine bay on my aftermarket regulator. i am also installing a oil temp guage, vacuum/boost guage, air-fuel ratio guage, hopefully a trans temp guage(still need to buy that one0 and a total of 5 temp guages..three pyrometers for the exhaust gas temp and two more for the indivdual cylinder head temps.... and maybe some brake bias guages too!!!
oops i misspelled gauges multiple times?!what the crap?
Network Native
Any gauge is an added failure point, I would never permanently install one on anything critical without a REAL good reason.
One on the fuel rail "maybe". Its fairly frequent that I would like to quickly rule out fuel pressure issues, messy to open, and fuel gauges from Roger at least seem at this point reliable. |
Well I agree, more to go wrong. I am trying to figure out why it was hard starting when hot. I have not started the car now for a month as I was doing some other work on it. Replaced the heater valve, put a new hose clamp on the power steering reservoir. Considering replacing fuel hoses now. The car has 45K original miles on it and most of the hoses look still pretty good. But they are 25 years old! I am also cleaning ground points.
generally speaking a gauge failure will not put your car on the side of the road, i have worked on cars for years and feel like the added protection of knowing what is going on with your car is more important. The fuel pressure gauge underhood is on a aeroquip dry break quick disconnect..so no gauge is there under noral conditions..just when i am underhood and wanting to adjust fuel pressure for some reason. In any event you never see race cars breaking because they had too many gauges(?) maybe not enough and the driver was ignorant of the car's condition...honestly think about the fact that you guys feel a gauge is a failure point, really?
Network Native
Not worried about the gauge, worried about modification to the fuel rail and leaks in the connections, and not just leaks at install time, but leaks that maybe happen after 5 years of this new "knob" getting bumped during normal PM.
rail gauge
oh. my gauge is not in my rail, it's on my aftermarket regulator.You just have to make sure you inspect for leaks at each oil change I guess.
