-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   RE:intake/spider whats that (http://forums.pelicanparts.com/porsche-928-technical-forum/584041-re-intake-spider-whats.html)
georges 928S 01-06-2011 08:32 PM
:confused:Hey Guys, may be stupid question, on 82 - 928 there is a hole in the back of the
intake/spider. is any thing suppose to go in there, i thought i saw some with plug
in them. i will appreciate any answers. thanks Ed.
Anthony10370 01-06-2011 08:57 PM
If it's at the top rear center and goes all the way through then it's for a bolt that goes through and presses on the center of the base of the air cleaner assembly to help it seal to the throttle body.
At least that's what it is on my '79.
-Anthony
MPDano 01-07-2011 04:35 AM
Yeah, the bolt is there on a CIS system like your 79. 82 is different. I am new to the EFI, so I can check on my newly acquired 83 for you after work today. Unless someone chimes in with the answer sooner.
joejoe1 01-07-2011 07:00 AM
Should be a plug there.
neil30076 01-07-2011 07:21 AM
Usually has a plug, but IIRC it is cast right through and does not really need it.
georges 928S 01-08-2011 09:11 AM
RE: plug on intake
there is a plug on there ,but it has a hole in it. will this cause a vacume problem. thank Ed.
Maleficio 01-09-2011 01:54 PM
Can you feel it sucking air at idle?
georges 928S 01-09-2011 05:28 PM
RE: spider hole
malefecio, i see you have an 82 model, does yours have a plug with small
diameter hole in it. Ed.
