Fuel Lines & Brakes
I got the new fuel lines from Roger last week, so I think I will start replacing them today. Also, after this is done I will put fresh fluid in the brake system as I am sure it's all original from 1986. It might be a good idea to put PB blaster on the bleeder screws and let it sit. I plan on using ATE Super Blue fluid, available from Tire Rack.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Automotive Necromancer
project encouragemaent.
Yo go for it Sir! yes PB blaster good to soften things up. On the brake fluid...go with the inexpensive stuff or the first change out. IMHO, don't let the master run dry. Suck as much old stuff out with a turkey baster and mop up the reservoir with clean paper towels, add fresh stuff and pump it through the lines by bleeding at the caliper end. IOW...don't crack a brake line if you don't HAVE to, just crack bleeders. You get (most of ) the old stuff out with minimal effort. Come back in a few months and repeat the procedure.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
928: Serial Enabler
If your luck holds, the little rubber caps are still in-place on the calipers.
If not, be prepared to remove the bleeders to clear them of sand.
84,85,86 928 cars |
I know the front pads and rotors were replaced once by the dealer at about 30K. They looked quite new the last time I checked. That might have been in 1992, when the work was done! Amazing.
928: Serial Enabler
Its amazing how many rich people bought these and let them sit.
One guy bought an 82 with 3500 miles on it.
84,85,86 928 cars |
Yes, unbelievable how some are still around. I was lucky, got mine through a friend. Not really looking for one. Just happened. The original owner had other cars and maybe got tired of the 928. He was quite wealthy, so did not mean too much I guess. Wealth does not necessarily make you happy, in fact can make one very unhappy.....sorry did not mean to carry on.
928: Serial Enabler
Same here. Family was tired of it. Came to us with 73K miles for $2K. Unbelievable value.
84,85,86 928 cars |
Recovering dismantler
LOL, I went from paying $43,000 for my 81 new in 82, to $1100 in 2009 for the 84 Euro S, to $3000 in 2010 for the 86 - probably spent for parts, etc in that time $10k. Not a bad ROI.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
jdill
harborman, in case you dont know start at the wheel furthest away from master cyl RR then LR . RF. last LF, super blue is easily recognized ,a cheap vac system speeds things up ,and it good idea to vac out master first before you start, people with track cars do this after every event usually,its tech requiremnet to show documented proof of fluid change, if gravity bleeding it can be long story but always watch the master does not empty, get a vacula and change fluid in all ur cars,its great to have,small investment for great tool
jdill
928: Serial Enabler
84,85,86 928 cars |
jdill
oh , sorry i wasnt even aware there was a bleeder on the master, ive always just sucked out the resevoir and refilled first, always learning
928: Serial Enabler
The workshop manual is always worth checking before you embark on something new. Sometimes its spotty coverage, but there is almost always some very specific and important information in it, even on mundane stuff like this.
I'm glad also to know that the antilock brake unit doesn't need special bleeding for these 86 cars, for instance.
84,85,86 928 cars |
Good project(s). With fuel line R&R, I would take care to not disturb some of the rear bolts with out PB Blaster first. A fuel line under the fuel cooler happens to be pretty low and if remove some bracketry can be a problem, also the connector/ CPS is most accessible/ vulnerable at this point.
Regards,
Bernard |
jdill
well after further research landseer the bleeder is on the top of the master,so all its doing is draining the resevoir, i see what the manual says, but vacing out the res is doing the same thing, myself i wouldnt open that bleeder unless i was replacing the master to get the air out. all the fluid is going to get pushed out anyhow,thats my opinion, as far as the tech manual goes, its a guide but ive found many things can be done much easier with the same results, along with plenty of misprints TMHO peace
928: Serial Enabler
Stick to bodywork.
84,85,86 928 cars |
jdill
you probably got a manual for that to go by also,FYI I asked the two top porsche repair shops in the boston area and neither touch the master to change fluid, what should they stick to ?
