86 alarm bypass
Having intermittent problems with my factory alarm. How can I bypass the alarm on a 1986?
Old 02-21-2011, 01:58 AM
928: Serial Enabler
There is a flat 8 pin black connector behind the CE panel.
I think its the only flat one with 8 positions --- you may have to lean the panel forward to find it.
Unplug. Take the female half. Link the wires at terminals 4 (black/red) and 1 (yellow).
Wrap some electrical tape around each of the now-separate halves. Tuck them behind the panel.
Intermittency often comes from corrosion in the 2 door contact pins, the hatch contact pin buried below the lower hatch receiver, as well as corrosion within tiny contact switches installed at the base of each of the 3 alarm lock cylinders.
84,85,86 928 cars
Old 02-21-2011, 04:47 AM
Thank you.
I have had an issue twice with the alarm not resetting while parked on an incline. Cranks with no start. If I move the car (push) several feet it will start right up. Is there also a sensor in the system that detects the degree of angle to prevent towing?
Thank you again
Old 02-21-2011, 06:00 AM
928: Serial Enabler
Interesting.
There might be a mercury switch in the hood, embeded in the light holder. Not sure.
Hood light should trigger with parking lights on, and hood open.
There is a push switch also, not sure its function, might be the electric fan safety switch.
Good question. Wally Plumley would know.
84,85,86 928 cars
Old 02-21-2011, 06:15 AM
