heater fan location
do you need to remove the hood to remove heater fan on 81 928 mines blowing a fuse if the switch is turned on.im thinking its either stuck or jammed with leaves maybe?is it located under right side on the windshield i think i can see to top of it there.
Old 03-14-2011, 03:22 PM
928: Serial Enabler
Far easier, yes.
Take a thin, sharp pencil and trace the hinge against the hood before removing.
Search about the blower fan. You should find some bearing lube information. Stan did a good writeup. My 16V grounds cleaning thread has a few pictures.
The fan can seize in the bearings. Also, there is a resistor set mounted in the air plenum. Different fan settings engage resistor coils to use energy, slowing the motor. Gets real hot, too.
When you remove the fan you can inspect the plenum for mouse nestings and you might want to consider replacing the resistor. Old isn't available. Newer one requires a couple wire swaps to work right.
84,85,86 928 cars
Old 03-14-2011, 05:04 PM
Recovering dismantler
neil30076's Avatar
Welcome to the board, whatever you do, wait until after the 17th to do it - my best memories of Dublin were spending St Patricks day at the pub on the Liffey , right by the Irish Revenue Commissions building.
I'm an ex-pat Brit, but as the saying goes -
May St. Patrick guard you wherever you go ...
Cheers
Neil
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 03-14-2011, 05:46 PM
cheers neil seems like a great site for info.i will take your advice on the paddys day thing, in no major rush to sort this problem i still have plenty of heat once on the move. its a little milder here than usual so not having the fans no problem. mark
Old 03-15-2011, 01:21 AM
