-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Fluctuating voltage: fixed. (http://forums.pelicanparts.com/porsche-928-technical-forum/597684-fluctuating-voltage-fixed.html)
Maleficio 03-18-2011 03:36 PM
I bought a voltage stabilizer from a Japanese company. Product is called "Raizin". Just a cap pack you bolt up to the battery. Instantly cured my fluctuating voltage problem. Perfectly stable now.
As the engine heated up, heat soak set in and the volts slowly dropped from 14 to 13, but crazy random dipping now.
The exhaust is quieter, the heavy burble when I let off the gas is reduced.
The car's running great, $45 off eBay. Money well spent. I hope it lasts a long time.
MPDano 03-18-2011 04:32 PM
Interesting. I would love to hear your thoughts on this after a couple months of testing. What's the technology involved in this?
neil30076 03-18-2011 04:41 PM
A hunking great capacitor and and inductor to smooth out the voltage transients! Sort of like the LC networks used on big power amps and cross over networks to improve bass response!
Maleficio 03-18-2011 04:41 PM
Four or five caps in a plastic box. That's all I know, and it works.
Maleficio 03-18-2011 04:42 PM
I'll post pics when I get home.
neil30076 03-18-2011 04:44 PM
Yes, if you put a big capacitor ( or network of same) across the battery you will stabilize the voltage, fast rise time ( to charge) and slow to deplete, and the volts look to stay constant. Try disconnecting the battery with the device in place and watch how long the 12v stays present!
Landseer 03-18-2011 04:49 PM
The voltage gage moves on all 5 of mine.
Including the 86 with new battery, new Bosch-rebuilt alt and all grounds and fuse box polished clean.
Normal.
Go drive it.
neil30076 03-18-2011 04:55 PM
+ 1 on what Chris said all mine fluctuate, i ignore it.
- looks like you bought the infamous Japanese flux capacitor :-)
Maleficio 03-18-2011 05:01 PM
:d
Maleficio 03-18-2011 05:02 PM
I just wish'd I could get 14 volts at all times, instead of during warmup only.
Landseer 03-18-2011 05:38 PM
Why? Mine never see that. Really, enjoy the car. You bought it for the right money and its really a great vehicle.
neil30076 03-18-2011 05:45 PM
Maleficio, don't worry about it - if you want an accurate voltage reading run wires from the battery up to a digital voltmeter !
I have owned 928's for over 30 years now, and a fluctuating voltage reading on the console has never worried me.
Drive, enjoy and don't be a worry head.
regards
Neil
Maleficio 03-18-2011 06:01 PM
:) I do enjoy it. Now I've got stable voltage,and I enjoy that, too. The car has never run better. Running well from stable volts, or placebo? No idea.
Landseer 03-18-2011 06:08 PM
Doesn't matter.
But if you have such an urge to fix stuff, might be time to get an engineering degree at Virginia Tech.
Just don't mess up the car.
Maleficio 03-18-2011 06:21 PM
A cap set will mess up the car? :D
It works as advertised. It doesn't make more volts, just stabilizes what the alt makes. It works well.
Maleficio 03-18-2011 06:22 PM
I'd love to back to school, but I lost my GI Bill in the divorce.
Fredfox 03-18-2011 07:26 PM
Wont the caps put a small drain on the battery?
Maleficio 03-19-2011 06:33 AM
Yes, but it's tiny.
http://forums.pelicanparts.com/uploa...1300541524.jpg
http://forums.pelicanparts.com/uploa...1300541557.jpg
MPDano 03-19-2011 08:37 AM
Now how does that happen? I never heard of losing your Chapter 30 Bennys to divorce. If your the Soldier and put money into it, then it's yours.
MPDano 03-19-2011 08:41 AM
Ah, now I see the benefits. I do remember back in the day when you would put in a hugeass Capacitor when you ran a super huge Sub/Amp. So the Cap hold some of the charge so your gauge doesn't bounce, as well as dimming lights with the Bass.
Fosgate has one. I bet this is the same idea.
http://ep.yimg.com/ca/I/mobile-emotions_1667_3004910
