Idle speed "pulsing"
I need some help with my 1988 928S4Auto. Since a layup, the idle speed has been erratic. There seems to be 2 symptoms.
1) When I pull up at lights or junctions the idle will hold 900 for a while then falter and die. It will restart immediately.
2) Sometimes it will pulse between 1200 and 1800 at a standstill, like someone is pressing the throttle every second.
Any pointers would be gratefully received.
Colin
Old 01-17-2002, 05:53 AM
Author of "101 Projects"
Wayne 962's Avatar
This problem (on all cars) is typically a mixture problem. If you have access, go to a shop, and have them check the CO output of the exhaust. This will give you an indication of the current mixture setting.
The hunting problem is ususally a symptom of the mixture being too rich, and the car oscillating, trying to adjust...
-Wayne
Old 01-17-2002, 09:59 AM
jrenfrew's Avatar
I would agree... But you may even have two troubles...
Idle hunting above idle (1200 --> 1800) strong chance of mixture problem.
Idle hunting below idle (200 --> 1000) stong chance of a fuel accumilator failiure or on electronic injection cars, the failiure of the idle stabilizer.
Just my two cents.
James Renfrew
75 Porsche 914
78 Porsche 928
Old 02-17-2002, 01:52 AM
Senior Member
Hello
Sounds like far to rich . First to check is the EFI-NTC on the waterneck.
Grüsse
Old 02-18-2002, 02:04 AM
Thanks for your suggestions. I am out of the country at the moment and am waiting for a decent day back home to try out these tips.
Colin
Old 02-26-2002, 08:51 AM
but out of interest, what is the EFI-NTC ? and where is the waterneck?
Old 02-26-2002, 08:52 AM
As written above, you need to check all the maintenance parts; air filter, spark plugs and wires, distributor caps and rotors,
O2 sensor and coolant temp sensor. Hopefully testing these parts will find the cause.
If not then it's likely there is a vacuum or air leak somewhere or the air flow sensor is beginning to fail.
We have found that many of the S4 modela have vacuum leaks at the intake manifold gasket (there is a bulletin for this) and when the manifold is removed many of the vacuum hoses are cracked or hard and leaking. The last three we have done have had warped manifolds too......
Firstly concentrate on the basics and when you can verify that everything is working correctly start looking at air leaks, air flow sensor, fuel pressure regulator and other stuff.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-26-2002, 05:54 PM
Senior Member
Hello
EFI = Electronic Fuel Injection
NTC = Negative Temperature Coiffiecient
This descripes the important temperaturesensor for the EFI Fuel calculation. That part sits on the waterneck. Thats the part where the thermostate sits in the mid front from the V Block. Its a bit beside on the driverside.
At least the US V8 crowd say waterneck to that part
There is also a seperate Temperature Sender for the instrument.
If you visit some pages you will find pictures and descriptions.
Top sites:
http://sis125.berkeley.edu/928
http://members.rennlist.com/v1uhoh/index.htm
http://www.nichols.nu/tips.htm
http://addicted.to/928/
Not so top:
http://www.rennlist.org/techarticles/928/928enginefaq.htm
http://www.kondratyev.com/porsche/
Grüsse
Old 03-01-2002, 12:41 AM
