-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Would one of you please test my L-Jet computer? (http://forums.pelicanparts.com/porsche-928-technical-forum/602011-would-one-you-please-test-my-l-jet-computer.html)
Maleficio 04-09-2011 12:08 PM
I want to ship my L-Jet computer to one of you with a good running 82 or so, and tell me if it's good or not.
Any takers?
2Quick4u928 04-10-2011 10:06 AM
PM me directly....will provide you with more info
Best of weekend to you
stepson 04-10-2011 09:40 PM
Send it to Sean or Roger. They should have a car that they can test it on.
Maleficio 04-11-2011 05:42 AM
Cool. I sprayed starter fluid into the intake. Car ran for a little while, ignition is good. Now I need to buy an injector noid to verify pulsing. I have 12 volts on both sides of injector circuits.
Landseer 04-11-2011 06:55 AM
Why not leave it be? Its working.
Sounds like there is simply a fuel delivery issue.
joejoe1 04-11-2011 07:18 AM
Car ran for a bit with starting fluid? Sounds kind of like what an acquaintance had going on. In his '84 he had added much in the way of stereo equipment and one day car just died. Checked fuel spark etc. car would start, but not run. Problem turned out to be main ground from battery where majority of stereo was grounded.
Maleficio 04-11-2011 09:27 AM
I'm going to start with the fuel pumps and filter, and work downstream to the regulators. It's finally warmed up outside.
