-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Need a replacement (http://forums.pelicanparts.com/porsche-928-technical-forum/604678-need-replacement.html)
Wrentham636 04-23-2011 08:35 PM
Need a replacement
This boot needs replacement but I have not been able to find anyone that sells this piece. Does anyone have a source? Gear shift on 5sp comes up through this boot. :confused:
http://forums.pelicanparts.com/uploa...1303616091.jpg
nuc 04-23-2011 10:16 PM
Call Roger at 928'srus on Moday. :)
Landseer 04-24-2011 04:35 AM
4 years in to this hobby, having worked on a dozen cars now and resurected 5 of my own, 928sRUS or 928 International are the places from which I buy new parts. Honest, professionally run businesess and highly engaged. If its not available new, or used from 928 Intl, then I go to individuals parting cars. (corp purchasing is my field btw) I have experience experimenting with other suppliers as well.
They say Sunset Porsche on the west coast is another solid choice for new parts --- discount too.
Pelican also has a good reputation for parts they confirm they have in-stock.
Wrentham636 04-24-2011 06:12 AM
Maybe if I knew proper name for this part I could find it easier. I've been calling it a boot but I keep finding the inside the cabin leather boot around shifter. Happy Easter all!
Wrentham636 04-24-2011 06:13 AM
Will do, gracias. :D
MPDano 04-24-2011 06:40 AM
PET calls it a "Sleeve
http://forums.pelicanparts.com/uploa...1303652314.jpg
http://forums.pelicanparts.com/uploa...1303652426.jpg
http://forums.pelicanparts.com/uploa...1303652436.jpg
MPDano 04-24-2011 06:42 AM
Right here on Pelican for $9.25
OEM-92842418104
Genuine Porsche Part: SHIFT SLEEVE
- This is a special-order, non-returnable, Porsche part
(availability and shipping charges may vary). [More Info]
$9.25
Landseer 04-24-2011 07:09 AM
Perfect. They get direct shipments from Porsche and shouldn't burn you on special shipping, though. If special upcharges, triangulate with the other two potential suppliers
These PET diagrams are useful.
MPDano 04-24-2011 07:24 AM
PET is free. Can I re-distribute legally? If so, I can post it up on my website.
Wrentham636 04-25-2011 02:38 PM
Awesome thanks Guys. Now I can only get one made of steel to keep another chipmunk attack. :mad:
bluemane500 04-25-2011 04:12 PM
YouTube - Dramatic Chipmunk
Wrentham636 04-27-2011 02:45 PM
Any tips on pulling the pulley off my old alternator? No issues getting the nut off using impact gun. Tried penetrating oil and letting it sit for a day. Tried heating the pulley. If it takes a special tool point me at a good one. Checked the tools selection on Pelican but nothing for this specifically. Trolled the posts here but again, nothing on this specifically. As always, your help is appreciated. :)
MPDano 04-27-2011 03:03 PM
Mine came off relatively easy. I used a large screwdriver for leverage and nudged each side and it eventually broke free.
JhwShark 04-27-2011 03:41 PM
+1...or get a pulley puller (if cost is an issue, buy it tape it pull it untape it then return it)
neil30076 04-27-2011 03:55 PM
rent a puller for a day from Kragen or autozone.
Wrentham636 04-27-2011 06:03 PM
Puller rented, pulley is off. No key with the new one and the old key is just a little large. May try to reduce thickness enough to make it fit.
