-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Having trouble finding a relay for my electric cooling fan. (http://forums.pelicanparts.com/porsche-928-technical-forum/606458-having-trouble-finding-relay-my-electric-cooling-fan.html)
Maleficio 05-03-2011 02:35 PM
I jumped 30 to 87 and the cooling fan runs. I read out the relay and it's bad. Intermittent open/close even without power applied.
The part number on the relay comes up as "fuel pump" when I search it.
92861511301
*********** sells a cheap bridge-style relay for $8.
Pelican doesn't offer this relay, but brings up fuel pump relay. The schematics are nearly identical, but not exactly the same.
Any suggestions?
SmileWavy
MPDano 05-03-2011 02:42 PM
See 82 Relay and Fuse Chart, there are many in your CE that are the same Relay
82 Fuse/Relay Chart
141.951.253.B
Maleficio 05-03-2011 02:57 PM
82 Fuse/Relay Chart
141.951.253.B
Thanx. :cool:
MPDano 05-03-2011 03:04 PM
I would switch it with X for now. It's the same as your Horn Relay. Unless you use your Horn all the time.
Maleficio 05-03-2011 04:11 PM
Cool.
Sapientoni 05-26-2011 10:40 AM
I think there's a relay used in some Caddy's that'll plug right in. I think it's Bosch. Usually found under the hood in 90's =.
Landseer 05-26-2011 11:10 AM
Call Roger. $5 each new.
