-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   turn signals??? (http://forums.pelicanparts.com/porsche-928-technical-forum/607679-turn-signals.html)
a320 05-09-2011 02:05 PM
turn signals???
1980 928, all turns signals are inop. Emerg flashers are also inop.. This car has very little if any corrosion. 56,000 miles.. Point me in the correct direction....
Phil
MPDano 05-09-2011 02:08 PM
Phil
Check your relay. Also, looks like you have a slew of fuses to check too:
80 Fuse/Relay Chart
a320 05-09-2011 02:13 PM
inop turns
Fuses are all good. opened up the relay, all looks new..
gbgastowers 05-10-2011 07:37 PM
When I had my flasher button out of the pod the turn signals would not work. When I reconnected the flasher button everything worked so you may have a bad flasher button,flasher relay or bad connection to the button. It completes the circuit I am guessing. Gunar
Maleficio 05-10-2011 07:39 PM
A relay can "look good", but be bad. You've got to read it out with a meter with 12 volts applied to throw the internal switch to verify.
Dean_Fuller 05-10-2011 09:58 PM
When you say "inoperable" do you mean they don't blink or don't light up at all?
caspermj 05-11-2011 03:10 AM
Gonna "+1" that. Same deal on my '82 Benz, wired through that switch. Easy check.
Mrmerlin 05-11-2011 07:19 AM
warning dont let the pod switches lay in the holes unless they are seated or pulled completely free of the pod to do risks a short as the switches can easily ground to the pod since its aluminum and short the wire back to the CE panel.
Since your having issues with the flasher and TS I would disconnect the battery then pull the switches out and verify that the correct wires are going to the correct switch some of the wires/ plugs will fit other switches, once this is done then remove the lower steering column cover and inspect the rear of the TS switch see if possibly it has been mis installed and the connectors are not on the pins
a320 05-13-2011 03:17 AM
got it fixed
I did a by pass with the relay, flasher workes. Replaced the relay, system checks ok.
MPDano 05-13-2011 04:48 AM
Ah, so you put the old one back in after doing a bypass, then sounds like your contacts were just dirty. Time to dig into your CE Panel with a small wire brush.
