-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Problems with AC compressors (http://forums.pelicanparts.com/porsche-928-technical-forum/607788-problems-ac-compressors.html)
bmwbeemer7 05-10-2011 05:06 AM
I have a 1979 928 euro and my AC compressor is not working. I checked the clutch with a hot wire and it does not click at all. The clutch spins freely but it does noothing when I put 12v to it to check it. So I bought a used compressor from a salvage yard and the clutch on it is bad too because I ran the same test. What should I do? I saw a used clutch on 928 International for $150. Should I just go that route and change the clutch on the original compressor? I have the first gen compressors and not the one on the 80 model and up. I just need a compressor with a clutch that clicks when I put 12v to is so I can fix my AC. Any help on this will be greatly appreciated!! Thanks!!
MPDano 05-10-2011 05:52 AM
928 Intl Used Parts is guaranteed, so if no clicky, then you get another one.
bmwbeemer7 05-10-2011 09:28 AM
THANKS!! I just put in an order for one.
MPDano 05-10-2011 01:45 PM
Did you do an online order? If so, follow up with an email or phone cal to Tom. Sometimes, the stuff they put online isn't even in stock. Happened a couple time to me.
