2Quick4u928's Avatar
Bolt positioning//Steering Rack Tie Rod ends To S4 Knuckle
Hey guys,
Helping out a friend on his upgrade on a 928 DTM Track car project with S4 & beyond front suspension bits. His 928 technically is a 1983 928S, and he is almost completed with the upgrade and it is time to connect the steering rack tie rod ends (ball joints) to the S4 knuckle.
Question; Does the "bolt" from the tie rod end ball joint enter the hole in the S4 knuckle from the bottom or from the top? The 928 Service Manual he purchased in PDF format unfortunately is unclear and since his 928 was originally a 1983 and didn't dismantle the S4 front suspension, he needs assistance how it should go.
I have all my goods in storage since relocating back to the states, and the time frame has been awhile so I am no help to him. Feedback here would be much appreciated, thanks guys.
Keep up the great posts!!!
Pat
So. of the Rio Grande
Long distance relationship w/my 88' S4 5-Speed Bi-Turbo Widebody In Work; Italy
Old 07-03-2011, 05:13 PM
928: Serial Enabler
Look at the direction of the taper.
84,85,86 928 cars
Old 07-03-2011, 06:03 PM
Petie3rd
Mrmerlin's Avatar
as Chris said the taper of the spindle will dictate how things go together,
the tie rod will only fit in one way
Old 07-03-2011, 06:07 PM
Will pass on...thank you. Happy 4th to you all!!
Pat
Old 07-03-2011, 07:25 PM
