928 slave cylinder question
Hello, I just purchased a clutch slave cylinder for my 1982 928. after purchasing it i realized that i bought one from a 1986. there are 2 different part #`s for the different years. does anyone know if the 1986 one can be used in the 1982 and what are the differences, they appear to be similar. thanks Doug
Petie3rd
it might be down to a push rod difference,
if you have the same diameter , it should be stamped and the other dimensions look the same then you should be able to pull out the new pushrod and swap in the old one if they are different. grease the tips of the pushrods with hi temp grease
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
