central indicator panel
Well, I pulled mine out yesterday to see why it wouldn't work, and all the wires are gone!
~Roy 1983 928S US 4.7 auto, black/burgundy 77k M417 M438 I455 M468 M484 M490 M494 M533 M650 |
this may help ? not sure what year your working on ? :
most likely several places on one of the 2 boards need re soldering but also burned out resistors and capacitors . Moisture gets in the box > you can pry out the boards after bending the tap's back. They may be stuck in the Case some so take your time. Once out you can separate the boards from each other > Plastic pin clip Repairing your Porsche 928 Central Warning System (CWS) controller Link : http://members.rennlist.com/tom928/Porsche_928_CWS_Repair_rev1p0.pdf If your Warning is On all the time with the key on : Try turning on the key after unbolting the box to see if the warning light go's out with the box pulled back from ground . If the light go's out most likely the cause is in the box . (1) The easy Fix is to try a know working box (2) install a good box new or used . Someone on the forum may have one 1978 x 1983 box > ( number on the back of box perhaps like my 1980 > 928 641 602 .01 Last edited by aluminum; 05-28-2011 at 10:02 AM.. |
Hey, thanks for the info aluminum! I did see that link before but my problem is (at least) with the piece right below the climate control and above the stereo in the center console unit. When I removed it, the wires on the back were not attached. I found a 4 wire connector not attached to anything. I'm "guessing" this is what needs to be soldered back onto the back of the indicator panel. I didn't see any other stray wires under the console. I just don't know which ones go where. If I could find a picture of one I'd use that as a guide to get mine soldered up. Here's a pic:
Don't know if these pics help. On my 85 model I have two connectors coming off this unit. Also, the color wires you have in your connector here don't match with what I have. Can give you more detailed pics if that will help.
_ 1985 Porsche 928S "USA" 5spd Black, Tan Interior |
That's great Wrentham636
![]() Thanks for the help so far guys!
~Roy 1983 928S US 4.7 auto, black/burgundy 77k M417 M438 I455 M468 M484 M490 M494 M533 M650 Last edited by caspermj; 05-29-2011 at 01:14 AM.. |
Found a good pic on RL, got it soldered up
