ok I need some advice and thoughts. for the price it seems alright. but I'd like some feed back from you folks to see if I should go through with it.
![]() 1988 Porsche 928 Hatchback - Saskatoon Collector Cars For Sale - Kijiji Saskatoon Canada. |
Car looks nice and clean, price may be a tad high though. But really, how much selection of 928s do you have in Saskatoon anyway?
I live in Ontario from what the guy has told me.
Timing belt and water pump should probably done in another 30,000 or 40,000 km or so. No leaks. Dash is cracked. Leather is excellent. No cracks or chips in windshield. Sunroof is jammed, but motor and electrical is fine....needs to be taken apart and unjammed some day. Body has not one speck of rust. Original paint. Paint chips on nose and minor scratches and stuff. Two dents each the size of a quarter or so......hard to see unless you are looking for them. In other words, body is in good shape, car looks quite sharp. |
Petie3rd
if you like it buy it, Be aware that an intake refresh will cost about 3K in parts,
thats if it needs to be done
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
wow.. thank god I have a 16v. What parts bring up the price so much? From an outward observer it seems like a few gaskets and seals would do the trick. good to know
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Petie3rd
if you do some research on an intake refresh of an 87 or newer you will see lots of parts to replace as well as recoating the cam covers and the intake.
NOTE skipping replacing single parts usually results in an intake redux part 2 so Spark plug wires, caps and rotors, crank position sensor, new fuel injectors 4 hole TPS, 8 spark plugs, 5 oil block off pins for the cam journals, new tensioner pads for the cam chains 2 knock sensors 1 hall sensor, new fuel lines, intake gaskets, ISV, MAF rebuild, New MAF boot and plastic connectors new O 2 sensor various rubber vent hoses, new oil fill spout, new flappy pod, new cam cover gaskets and seals, new thermostat and seals as well as the water bridge seals if leaking. new vacuum line end rubbers
