-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   timing questions (http://forums.pelicanparts.com/porsche-928-technical-forum/619963-timing-questions.html)
Landseer 07-19-2011 04:53 PM
Both look shot. Looks like somebody tried to save the $ for new bushings by inserting a brass bushing on one of them.
A good used one should be an easy search, maybe for free or close to it.
Neil, not sure on the early cars how they changed.
trucker677 07-19-2011 05:08 PM
the part number I have for both of them is 928 105 540 1R, as for whether or not someone replaced the bearing I have no idea, when the bolt goes in there is no play or slop. if you look at the pics both of the wheels look different but they are the same dimensions and stick out the same, it looks like they have two different bearings in each. like mentioned earlier it came off of a good working car, so far no one else has seen this type of bearing and it is not in the book, thats why I was throwing it out there.
MPDano 07-19-2011 05:11 PM
I think Porken Tensioner is in your future. I wouldn't even try to rebuild that.
PorKen Products
Landseer 07-19-2011 05:19 PM
Somebody rigged it.
Not a bad idea particularly, but not stock.
Porkensioner is a possibility, but they require replacement of the tensioner cylinder with each timing belt. (I support an Audi shop and we have a small pile of tensioner cylinders that failed -- you can depress them with your thumb). The unit is fine, but its not a lifetime solution that people mistake it for.
trucker677 07-19-2011 07:52 PM
I am going to call tomorrow and see how much it is to replace the bearing and rollers and the washer and get it done right so I dont run into the same thing again.
Landseer 07-19-2011 08:20 PM
Might want to check on the gears, too, at least crank ( which is about $120 ) and oil pump ( maybe $65 ). Crank gear is often very sharp and angled.
trucker677 07-20-2011 02:36 PM
I am ordering a new tensioner bracket, new bearings and rollers, new nylon bushings so just I know I have the whole thing right, that was from 928 intl. I do have two bolts here that were on both brackets, one is shorter than the other, does anyone know the correct length of bolt to use, thread pitch and shank size, I just want to size the bolts to make sure I don't need new ones, he wants 20 bucks for the one bolt. that seems really steep.
neil30076 07-20-2011 03:11 PM
The bolt you need for an 82 is a 928.105.570.03, and it is 55 mm long.
and looks like this:
http://www.mailordercentral.com/928intl/prodinfo.asp?number=928%20105%20570%2003
kennner 07-20-2011 03:28 PM
You just had regular old bolts holding your tensioner arm Chris. Spend the 20 buck and get the right bolt for the job. It is still cheaper than a motor.
neil30076 07-20-2011 03:30 PM
It's only $13!
plus you need 2 x 999.924.003.40 ( nylon bushes)
and 1 x 928.105.572.00 ( washer/spacer)
to be 100% good.
kennner 07-20-2011 03:42 PM
13 bucks in the USA, but Canadian prices are always different.
neil30076 07-20-2011 03:45 PM
Sorry.
Did not know Chris is in Canada, not in his signature.
aluminum 07-20-2011 10:21 PM
Bolt $8.25
Wow $5 sounds good to me >>
but this Place has them for $8.25
Link :
dC AutomotiveOver 140,000 square feet of new and used Porsche parts
if yours is a 82 year
Don't over tighten that Bolt ! or it well strip out . You might use Lock Tight or some pipe Joint compound on it > just a dab .
Needs to be right as it controls the belt tracking as well as more .
Danglerb 07-21-2011 01:36 AM
If a factory shoulder bolt wasn't used, could be the block was drilled out and tapped or helicoiled to a non factory size. I suggest a close look at what you have once the parts are torn down.
Landseer 07-21-2011 03:20 AM
Good point.
The shoulder bolt, used to pivot the tensioner arm, mounts into threads tapped into the water pump, though, not the block. The threads must be sealed with something to prevent dripping.
It would be a great time to install a new Laso water pump.
Be careful, also, with the three bracket bolts. I think 1 is shorter?. Those three holes need to have great threads and the bolts need to be the right lengths. Timeserting is easily possible if needed to restore them, and any other threads that might have been stripped on the front of the block.
Good plan on going with the original parts. I think the tensioner arm is also suspect at this point.
For used parts, either 928 intl or a private enthusiast that has substituted the Porkensioner would be sources I'd pursue.
trucker677 07-22-2011 05:07 AM
I ordered all new parts so they should be here next week and then back at it again.
trucker677 07-28-2011 07:00 PM
So I got all of my new parts in today, I am going to be working on it tomorrow after work, does anyone know off hand what is the torque either in NM or ft lbs the bolt that goes in thru the bracket into the top roller which goes into the water pump, I can`t seem to find the torque spec for it. hopefully I will be running tomorrow night, maybe saturday.
trucker677 07-29-2011 06:48 PM
anyone??
MPDano 07-29-2011 07:49 PM
The thing is, I never use torque specs and I know I should but never have on any of my cars. I guess I have worked on so many that I just tighten by feel. I also use Blue Locktite so they never back out and blue is very easy to loosen back up. Never use the red stuff.
Sorry I didn't answer your question but I know someone here knows.
trucker677 07-31-2011 12:09 PM
so I got the car running today, drove it around for a few kms to make sure it was all good, then put the other belts on and tighten them all down. drove it around again to double make sure everything was good. no problems, went to gas station, got gas and was going to drive to my work and wash it, 16 km away, I made it half way and I could smell oil burning, I pulled over and looked underneath and then noticed a puddle under the car, I shut the car off. pulled dipstick and most of oil was gone, havent found source of leak, but went to start car again to get it off the road but it didnt start, it sounded like a whinning sound, almost like a timing belt was gone on a normal car. pulled no 1 spark plug and piston is moving up and down and you can hear the compression, havent down drivers side as of yet, if there is no oil in the car is there a switch or something that won't activate the car, is there anything I should be looking for in regards to this, has anyone ever had this before,
Landseer 07-31-2011 12:19 PM
Somebody had a front main seal pop-out of the block, but behind the crank gear, releasing huge amounts of oil. Pour some in and see where it comes out. (am assuming you had it full to begin with ).
No, the engine hasn't got a low oil safety interlock.
Did you replace or inspec the front main seal while inside for TB job?
What did you decide to do with the oil pump while inside?
trucker677 07-31-2011 05:40 PM
so the oil leak was from the tube on top of the oil pan, knocked the seal out of place, never noticed when putting it all back together. new seal and no leaks. got everything all back together again and went to start it and what do you know, no start, no spark in any of the spark plugs, no spark in the coil either, was going to pack it in for the night and tried one last time, started right up. I am thinking the green wire might be bad, how do you check it to see if it is bad.
Landseer 07-31-2011 06:15 PM
Look at condition of connectors, try not to disturb it though.
trucker677 07-31-2011 07:36 PM
they look good,
lfausty 08-11-2011 07:09 PM
think the bolt is 15nm 20ft lb. just laying the info down.(tensioner bolt
may just have been saturated oil on connection and your good now (no spark/coil)
sometimes after tb /wp done quirky little things can happen (the recheck, wires/fuse/relay/ground)
still wouldnt see need to pull rebuild engine. *pcar does loves to be motoring gets better and better, but it always seem to keep you on your toes the mystery of will i be stranded today, whether you want to play pcars game or not, 24/7
trucker677 08-12-2011 05:39 AM
I got it all back together and everything seems to be working good, the other day someone mentioned to me I had something in my exhaust pipe, I looked and I had two pieces of the guts from my cat just sitting there, I am going to cut that piece out and put a straight pipe in there.
MPDano 08-12-2011 06:14 AM
You can, but the easiest way is to just gut the Cat. I used a metal pipe and pounded it all out on another car back in the day.
