Rear diff fluid change 928s auto
How does one change the fluid in the rear diff on a 928s us auto?
Has anyone tried the synthetic fluids like Amsoil? |
This part is easy.
Conventional (tapered) plugs to remove, 17mm hex. Use a pump or run about a 1/2 inch hose from the fill hole, through the right rear fender well, and zip tie it to the fuel fill door. Fill. Am using Mobil 1 LS synthetic, on some, Valvoline inexpensive stuff on others. I think it calls for 75W85 or 75W90. At least 2 qts / check book. Don't overtighten plugs on reassembly. |
Synthetic from conventional switch on this no problem?
On the automatic transmissions, though, am now using Valvoline High Mileage ( red container ) these days because the Mobile 1 trans fluid doesn't shift as firmly on a couple of my cars as the Valvoline. The Valvoline might not be synthetic. I think the issue is the friction modifier package as opposed to the origination of the oil portion. |
I'm running Amsoil in mine, plus a dose of Tufoil. Works great.
I do remember Mrmerlin saying to open that fill plug on differential first before draining as some were hard to get off. I might tackle that job as well. |
Yes, you are right, I got that totally sideways!
But he and I were corresponding separately a few days ago on the trans fluid, so it must have gotten tangled up in my mind. Good call, bad communication on my part. The 5 speed has the diffy open to the trans, so they fill as-one with gear oil. The auto uses gear oil in the back, and trans fluid in front. Valvoline and Mobil 1 are brands of both gear and trans fluid --- am using all permutations right now, gets confusing sorry. |
I am going to try amsoil trans fluid and amsoil gear box fluid just waiting for new trans filter
yes will drain convertor as well
I just did my Differential fluid change today. Got a 17MM hex allen 1/2 drive socket at Autozone for $11, actually a 3 pack. The plugs came out easy on mine. I put some anti-seize on them before reinstalling them. My old fluid was actually not too bad looking but this car was well kept! As was the trans fluid when I did that. The pan was clean. Anyway, now I know it's all new.
Changing all the fluids, at least once at beginning of ownership, seems like a very positive thing to do.
We've begun disecting filters for clues to condition. Messy but revealing. |
