-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   central warning light system (http://forums.pelicanparts.com/porsche-928-technical-forum/623593-central-warning-light-system.html)
provenceman 08-08-2011 10:22 AM
Is it normal for the centrail warning system light to stay on once the car has been started
No other indivuidual warning lights are on and the central i indicator light is not flashing
All fluid levels seem to be ok
Once the car has started I can turn off the i warning light by pusjing it to reset it
provenceman
MPDano 08-08-2011 10:25 AM
Nope, it's not normal. In a normal situation, it will be on with the key in, once you start the car up, it will extinguish. There are a lot of variables. One common one is the Brake Pad Sensors.
provenceman 08-08-2011 10:35 AM
This is now begining to make some sense
When I first start out in the monring I do get a loud noise coming from the brakes and it then goes away shortly there after and does not come again when I break
This may well be the issue
So bad break wear sensor (s)
Maleficio 08-08-2011 03:28 PM
Or maybe the sensors are working properly, and your pads are shot? :)
Anthony10370 08-08-2011 10:51 PM
Also check the timing belt tension. There is a spring switch in the tensioner on the later models.
-Anthony
Mrmerlin 08-09-2011 07:21 AM
need more info.
The I light will be on after the car is started,
IF the E brake is pulled ,
release E brake it should go off.
If not then the switch under the E brake handle may need to be adjusted
also the brake light warning will be lit till you step on the brake,
if the I light stays on after this then you need to check the warning lights,
to do that get the owners manual and see what the warning lights are then turn on the key and see if they are all lighting up,
if any of them are out then that system may be suspect as triggering the I light
provenceman 08-09-2011 10:45 AM
central warning system
Thanks everyone
Will check the pads and see if this corrects the problem
If not one to the timing belt tension and the e brake
As always appreciate the help
Mrmerlin 08-09-2011 11:12 AM
before you do anything else,
please follow the instructions i posted the #6 thread
MPDano 08-09-2011 04:29 PM
Just try and do this test (emergency brake release) on level ground. No need to put stress on your Tranny Gears.
9two8 08-10-2011 07:30 AM
Quote-- No other indivuidual warning lights are on and the central i indicator light is not flashing, Unquote.
sorry if I,ve mis-read this, but if no other warning lights are showing on the pod how do we know it,s "Brake pad warning"
Mrmerlin 08-10-2011 08:29 AM
By following the instructions in post 6 answers to what warning might be on will be answered
provenceman 08-10-2011 01:31 PM
Thanks Mrmerlin
Will try this first
