Dashboard change
well after searching hi and low ,i finally found a new dashboard on ebay without cracks,it just so happens it was done in vinyl and withstood the test of time, 30 yrs later it still looks brand new,i thought it would be a difficult job but it was not bad at all, turns out the dash is only held on by 4 screws, once all the bologna is out of the way,
http://forums.pelicanparts.com/uploa...1313446011.jpg |
The term "WYAIT" comes to mind! How does your air conditioner work? The vacuum servos are ALWAYS a liability, and typically dead at this point. It would be good to refresh all of them, and buy a rebuilt climate control head while your at it. I just spent $1000 trying to get my AC working, and it is about.....50%. If the car has been in the garage it is cool. If it is in the sun for any time at all...I bake while driving. I should pull the dashboard, but this will likely take me a month or more, with my schedule, and I enjoy driving the car- My other car, a Ford Aerostar really is not exactly an inspiration toward spirited driving....
[It hauls plants and much very well!] Good luck. N! |
my ac is great,, works perfectly but i did close off the line to heater core for the summer, the only issue i have is the cluster odometer,, and i have a small crack in the pod
http://forums.pelicanparts.com/uploa...1313446767.jpg |
i want to send the cluster to vdo for odometer gear,,, anyone have a suggestion? and recover the pod?? norm so far i have six hrs in the job its pretty simple
FTE LAUDERDALE SPPEDO wants 225 and i just got off the phone with no hollywood speedo and they are at 110, tommorow i will ship to cali.......i dont know what to do with the pod?
There are absolutely great instructions available on how to do the odometer drive gear yourself. Since you have the pod out already I would guess it would take no more than an hour to do it yourself. I have done it to 3 cars and it is no big deal....
How necessary was it to take seats out?
Changing an odometer drive gear doesn't screw up anything, unless you do! Where do you think the odometer rebuilders get their parts? I have also rebuilt many, and none have since failed.
Oh, and accuracy of gauges on a 928 pod are a joke ! |
LOL. So your voltmeter, temp and others is accurate?
I don't doubt that a VDO shop can get parts from the factory for a 79 or 85; I suspect that Roger, Mark and others get from the same source . I'll watch your post, and not respond again...... |
Sheesh........relax, fellas.
now is the time to replace the console pods 2 of them and you can test the defroster but probably leave it alone as it seldom leaks also replace the pod in the blower box and fit a new heater control valve and short hose with new parts the system will work as advertised
Number of factory VDO gears that have failed, all of them. Number of aftermarket gears that have failed, none I know of. |
nice find on the clean used used dash.. It looks great. The dashes do come out easy.. so do piston rings...once you get there. :D
[QUOTE=neil30076;6198188]LOL. So your voltmeter, temp and others is accurate?
I don't doubt that a VDO shop can get parts from the factory for a 79 or 85; I suspect that Roger, Mark and others get from the same source . I'll watch your post, and not respond again......[/QUOT your response is not a problem neil but an authorized vdo repair shop does get their parts from the factory., im all for do yourself but im not a great big fan of aftermarket,,, i will use aftermarket when their is no other solution,but in this case i choose to go with oem,,,btw my other guages all work perfectly in this 85, in my experience the guages can be calibrated, the signal is usually the issue |
| All times are GMT -8. The time now is 02:15 PM. |
