Let's Talk California Smog
Ok, I failed my Smog Test again today.
I was able to bring my HC down by ridding the stumble on acceleration. It's close but no cigar. 1) What I did to eliminate the stumble was to remove the vacuum to the Diverter Valve, which open the valve to let air from the Smog Pump in the Exhaust. I can make it stumble by putting a vacuum pump on the Diverter Valve. 2) Since I disconnected this, I no longer am putting air into the Exhaust, which I believe is why my Nox went up. 3) I am ready to have my spare "new" Catalytic Converter Welded on since I have a feeling my Cat went bad since the car always ran very lean. Please take a look at the Smog Test results and throw me some ideas. This is the last PASS in 2009 http://forums.pelicanparts.com/uploa...1314160933.jpg This was the FAIL in June 2011 http://forums.pelicanparts.com/uploa...1314160937.jpg This the FAIL yesterday - Aug 2011 http://forums.pelicanparts.com/uploa...1314160944.jpg |
I cant help you on this Leo, we don't have smog check in Ohio (yet.....)
Heet
Move.
Comparing 09 to now, HC is way too high AND NO is over limit, sounds to me like the injectors aren't balanced or have bad patterns etc., some lean, some rich, not looking good for the cat either.
Maybe try and look at each or some of the legs of the exhaust header with a IR temp gun? |
The diverter valve would only cause the car to stumble if it had a vacuum leak.
Whether the smog pump is pumping air into the exhaust or diverting it out, it shouldn't cause a stumble. |
Check out these links:
What Causes High NO - Nitrous Oxide - SmogTips.com. Why did my car fail emission test high NO emissions. What is NO. My vehicle failed high nitrous oxide emissions test. Produced high NO. Common high NO failures. NO emissions. How can I lower NOx. Co What causes high HC. What causes high Hydrocarbon - SmogTips.com. Failed HC Emissions. Why did my car fail the emission test for high HC emissions. What is HC. My vehicle failed the emission test for high Hydrocarbons. Why my car produced high HC. Hi Check your timing and a/f ratio...retard slightly and richen the mixture a bit. A guess on the stumble with the diverter connected is the a/f going too lean. |
Oops, I think I confused the diverter with the EGR system...check the EGR system.
I need to look more at my vacuum line set up. The Diverter Valve should be connected to vacuum line that vacuums only on throttle up, correct? |
I can cruise by on Sunday AM and we can go over all the vac lines.
Diverter sends the air pump flow to either the cats or the air filter box. Used I think only during cold start when mixture is rich.
I got a lot to learn about the stupid smog system. Is there a diagram for us CISers on the Smog System and routing? |
Typical air injection is just "someplace" in the exhaust pre cat.
EGR is routing some exhaust back to the intake side to "I think" reduce peak burn temperatures in the cylinder that create NO when the mix is very lean. |
I found a Euro Vac Diagram and everything looks like mine "except" I never saw a Vacuum Control Valve" (#5) on my set up.
Also, if looking from above the engine, the 3 vacuum ports coming out of the rear of the Throttle Body (#2), looks like the center port goes both tho the Decel and Diverter Valves. The left port goes to the lower port on the WUR. How do you check a "Check Valve" (#9)? http://forums.pelicanparts.com/uploa...1314292152.jpg |
A check valve is simply a one-way valve. Hook up a mity-vac or similar and ensure that one side holds a vacuum and the other doesn't.
Valve 9 is a one way check valve, it's to keep the hot exhaust from flowing back into the diverter valve and burning it up. The check valve is back between the firewall and engine block on mine. To check, disconnect the hose between 8 and 9, when you start up the car there should be no flow coming out of 9. In fact, due to the venturi effect may actually have a little suction present, so have someone blip on the throttle to make sure you don't get any flow OUT. In ok, out bad. |
| All times are GMT -8. The time now is 10:03 PM. |
