coolant temp sensor
I think I have a faulty coolant temp sensor
Is this the sensor that is located at the top of the water pump There are other sensors on the engine and want to make sure I get the coorect part Thanks for your help Regards provenceman |
I believe you are talking about the Temperature Sensor II. It is located on the Water Bridge just above the thermostat.
http://forums.pelicanparts.com/uploa...1315241118.jpg There are some testing parameters included above. Test to be sure the sensor is bad before replacing. |
EDIT - Sorry, I didn't check the MY - The info above is for the early 16valve engine. I don't have the WSM for the 32 Valve models. :o
coolant temp sensor
No problem
Thanks for responding provenceman |
| All times are GMT -8. The time now is 11:44 AM. |
