-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Where the heck is the ATF reservoir? (http://forums.pelicanparts.com/porsche-928-technical-forum/63038-where-heck-atf-reservoir.html)
TheStig 03-17-2002 09:18 PM
Where's the ATF reservoir on my 1987 928S4...I'm only a 2 day old 928 owner....I looked in the manual but i still can't find it underneath the rear of the car.
Britwrench 03-17-2002 09:36 PM
It's on the right hand side of the transmission..only check it with the engine running, trans in Park and at normal operating temperature (or hot as it sometimes known as).
It's real difficult to see unless the car is on a hoist.
Wayne 962 03-18-2002 02:25 AM
I would suggest four jack stands - making sure to keep the car level...
-Wayne
Roland Kunz 03-26-2002 05:56 PM
Hello
If you look from the rear at your car and go down onto groundlevel you will see the canister on the right rear beside the axlehousing and if you can see the level abouve the steel brace holding the plastic canister you have enough to maximum.
Refill is a bit harder and needs a shop lift.
Grüsse
