-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   RE: cold start problem (http://forums.pelicanparts.com/porsche-928-technical-forum/638060-re-cold-start-problem.html)
Landseer 11-07-2011 04:31 PM
Dealer was where I bought the last one.
Can't Roger order it?
And its not an "uncommon" problem. These sensors are aging out.
georges 928S 11-10-2011 01:28 PM
RE: cold start
Hi Guys,i got my new thermo time switch, but i was checking to see if there is power
coming to thermo switch plug, i only got ground with test light and nothing on the other
wire with the ignition on. is it suppose to be that or do i have problem with power not coming to the thermo from plug connector. Thanks. Ed.
vandenham 11-10-2011 01:37 PM
The wiring diagram I have shows that the power only comes on when the starter is operating.
georges 928S 11-10-2011 04:09 PM
RE: cold start
Guess what guys, i just put a brand new (thermo time switch) and still no go, so it must be something else. what should i do next, need help. Ed.
neil30076 11-10-2011 04:40 PM
Just to be sure, we are talking about the thermo time switch, mounted horizontally on the water bridge under the front pressure regulator.
OK, so lets do some more testing-
Unplug the thermoswitch and put a voltmeter ( NOT a test lamp) from W in the plug side to ground.
try to start, you should see 12 volts when the starter is turning. Do You?
Now move the voltmeter to the G pin in the plug and repeat, Do you see 12 volts ( or close to)
If you do not, your Start valve is either disconnected or bad.
If the test is good:
You can force the cold start valve to open by removing the plug from the thermoswitch, and putting a ground wire ( carefully)from the G terminal to ground and retry.
Report back what you find.
georges 928S 11-10-2011 04:54 PM
Thanks Neil, i will do that tomorrow and get back to you. Ed.
Landseer 11-10-2011 07:24 PM
Sorry Ed.
Will buy it from you if you want.
Let's let Neil run with it, he has proven excellent diagnostics / I'm generally just working a checklist.
georges 928S 11-10-2011 09:43 PM
Originally Posted by Landseer (Post 6364330)
Sorry Ed.
OH,dont worry landser, we all do the best we can to help, anyways the old one looked
like a charcoil. Thanks Ed.
neil30076 11-11-2011 07:47 AM
ED, PM me a phone number if you would like to talk after you run the tests, might be a lot easier than messages here.....
georges 928S 11-11-2011 07:59 AM
RE: cold start
Good morning Neil, i will start on this morning and let you know. any way my
cell # is 702-882-7842 you can call me and leave a message , so i can save your number to call later. Thanks for all your help. Ed.
neil30076 11-11-2011 08:39 AM
Sorry Ed.
Thanks for the compliment, Chris - unfortunately I have a lot of spare time to look over wiring diagrams and do this :)
- keep on saving our cars!
Regards
Neil
georges 928S 11-12-2011 10:56 AM
RE: cold start
Hi Neil, i pulled the thermo switch plug out and checked the volts from G to ground
and from W to ground and both readings were at 8.75 and 9.25 volts, they never reached 12 v so iam going to wait for your answer. call me at 702-882-7842 or give
me your number and i will call you. Thanks ED.
neil30076 11-13-2011 08:51 AM
Ed, voltage sounds way low - to make sure i am on exactly the right wiring diagram, please confirm the year of your car, and is it a euro?
I'll be able to call you later today ( Sunday)
georges 928S 11-13-2011 12:01 PM
RE: cold start
Hi Neil, its an 82 US model, i will be home at 3.00 pm. Thanks Ed.
neil30076 11-13-2011 04:02 PM
Ed, i'll call you shortly. I'm concerned you are only seeing around 9 volts from W to ground. W goes back via the infamous 14 pin connect to relay XIV, and directly to battery voltage - so should be at least 12 volts. At the 14 pin, pin 14 has 2 wires, a heavy yellow going to the starter, and a lighter one ( yellow) going to the cold start switch. This must be 12volts, At the plug going into the switch, there are 2 wires on W - both yellow) , 1 on G blue/yellow that goes off to the cold start valve.. If we are in the right area, i'm beginning to think you have a 14 pin problem. Does the starter engage easily, or is it slow to pull in?
georges 928S 11-16-2011 06:17 PM
RE: cold start
Hi Neil, sorry i didnt answer sooner, my starter engages very well . have no problem with it, i going to check the volts coming to the plug again ,just in case
didnt do it right and also check the 14 pin. goodby for now. Ed.
