-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   "Tail Light" error light on in my Cluster? (http://forums.pelicanparts.com/porsche-928-technical-forum/639121-tail-light-error-light-my-cluster.html)
MPDano 11-10-2011 08:59 AM
I have the "Tail Light" error light illuminated on my Dash. It keeps triggering the (!) light, so I have to keep resetting it. I checked my tail lights and they are fine, turn signals too.
I am wondering if this means something else and maybe this has happened to someone else and resolved it. Stumped :confused:
BTW, this is on my 83 "S"
neil30076 11-10-2011 09:47 AM
Happened infrequently on my 81 - I replaced all the tail and side light bulbs with fresh ones and haven't seen it since.
riber.bentsen 11-10-2011 10:06 AM
The system works by detecting different current draw on either side of the car. So, for instance, if you have a 5w bulb in the left hand cluster, and a 10w in the other the warning will trigger. Such a small wattage difference is not apparent to the naked eye and it can take some time figuring out... (Ask me how I know)
Another option (if it's not a fault within the control unit itself) is, that one sides wires, bulb socket or even bulb cord is corroded and therefore draws more amps. Anyway, gotta crack open those taillights and check it out bro!
tychain99 11-10-2011 12:03 PM
my stop light indicator illuminates when i start my car, i tap the brake, and it disappears. all my bulbs and markers work, Idk it does this but it is one of the few quirks i have found in my car.
neil30076 11-10-2011 12:13 PM
Stop light warning light should come on when you start, and go off when you apply pressure to the brake pedal - yours is working correctly.
riber.bentsen 11-10-2011 12:39 PM
my stop light indicator illuminates when i start my car, i tap the brake, and it disappears. All my bulbs and markers work, idk it does this but it is one of the few quirks i have found in my car.
rtfm!!!! ;) ;)
neil30076 11-10-2011 12:58 PM
LOL ^^^
tychain99 - do you have the owners manual?
Mrmerlin 11-10-2011 04:40 PM
Dano you most probably have a side marker light thats corroded I would inspect all 4 of them and install new side maker bulbs.
Also check the connections in the hatch area for the side markers.
Also make sure the bulbs match side to side in the rear and front
for parking ,
turn and brake sections
