possible motec M48 Pro for sale
I'm looking at upgrading, so I'm thinking about selling my m48 pro. Its currently set up to for a 928, using TPS with MAP sensors, no MAF needed. It includes the engine harness, files and basic tune for a 6.4 liter.
It will use the factory flywheel and cam sensors, as well as the factory water temp sensor, and the IAC under the intake.
It is probably the closest you will find in a plug in aftermarket setup .
The harness is not perfect, but is in good condition. This was a newly made harness that was made with milspec wire.
The bare harness sells for $500+ and that has one plug on it and 8 feet of individual wires. It has to be custom made for each car. This one was made identically to the factory 928 harness, used the factory routing, and has a factory boot where it goes through the firewall.
The motec is set up for sequential fuel injection, and works well for the 928. It even contains the wire for the timing belt sensor and works just like factory.
The motec M48 PRO has the data logging and lambda.
$2700.
Old 11-17-2011, 01:24 PM
