harborman's Avatar
Wheel Spacers
I was considering putting the 15mm on my rears. Has anyone used EZaccessory spacers? I am looking for the ones that use original studs and have another set of studs on them. I see 928motorsports has some.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 12-21-2011, 12:33 PM
Petie3rd
Mrmerlin's Avatar
Vertex sells them,
also look on the for sale boards usually a used set pops up from time to time,
use bolt on bolt on spacers
Old 12-21-2011, 02:57 PM
harborman's Avatar
Originally Posted by Mrmerlin View Post
Vertex sells them,
Thanks much, will check it out!!!
1986 928S
32 valve engine
Old 12-21-2011, 04:10 PM
harborman's Avatar
Vertex sells them,
Yes, I will get those for sure! Merry Christmas!!
1986 928S
32 valve engine
Old 12-21-2011, 04:45 PM
Petie3rd
Mrmerlin's Avatar
to figure out what size to get first you need to have the wheels /tires fitted that your going to run then measure from the outside tire edge to the inner lip of the outside fender measure both sides one may be closer to the edge than the other.
use the smaller number subtract 5MM from this number then get spacers that are as close to this number as possible EG 24MM left 28 mm right
24-5 = 19.
OR you can try to pull the smaller fender out gently with leather gloved hands pull with both hands together along the lower edge of the fender then remeasure.
the fender will come out some,
dont apply too much pressure so you dont damage the bodywork.
Merry Christmas to you and your family, Stan
Old 12-21-2011, 05:29 PM
harborman's Avatar
Will do, and check it all out before I buy any. I think it would make the car look nice. I have stock rims and tire size.
Thanks again, Rudy
1986 928S
32 valve engine
Old 12-22-2011, 04:51 AM
Petie3rd
Mrmerlin's Avatar
the reason the rear wheels on the 928 look sucked in is because they were made to facilitate the use of tire chains for winter driving,
if the tires were close to the fenders then they chains would damage the fender lips
Old 12-22-2011, 06:15 AM
