How to remove the plastic hatch latch.
Like the title says how do you remove the plastic latch from the lock assembly?
It looks to me like it is just a roll pin type pin but after some serious pounding on it it never budged (I hit it from both directions) is there a trick I am missing? |
I found this on banlist
How do you remove/disassemble the hatch upper latch? Now - Hatch rattle fix. - Rennlist Discussion Forums I guess I need to drill out that pin or to just put the latch in the press and press the pin out |
Hello, you might want to check the receiver part of the lock, it has a plastic incert which gets worn. This might be your problem. They are replaceable. If this piece is very worn you won't be able to latch your lock at all. Check it out. Thanks, Steve
Not saying it applies, but do you have roll pin punches?
Edit: Well I misread that the first time. I am missing mine so I better get one of those also while I am at it. |
Hatch Receiver Liner - Detailed item view - 928's R Us Porsche Parts Store Nicole Porsche 928 Hatch Receiver Liner |
