Need help in Redding California.
I thought I was going to make it with no issues! The car was running great and I had no troubles from Phoenix to LA to SF and up to Redding. But this morning I got in the car to make the last leg of the trip to Seattle and the clutch went to the floor. I have the shop in Phoenix helping me find a mechanic but I thought I would ask on here to get as much help as possible.
Old 01-30-2012, 09:36 AM
rjm65's Avatar
Look for obvious fluid leaks in the clutch hydraulics, i.e. around the master and slave cylinders. My driver's footwell was full of brake fluid when I purchased my 79 due to a leaky clutch master.
Start off by bleeding the clutch, maybe that will at least get you home where you can look into it deeper.
'79 - clutch master cylinder hose leak
Raymond
1979 928 5 spd
Old 01-30-2012, 09:48 AM
Network Native
Danglerb's Avatar
Blue hose, runs from the brake something to the clutch something, gets exposed to a lot of heat, eventually needs replacing.
You may need to register to see images, but you don't have to join.
SharkSkin - Shark Attack Round Thirty Two - Clutch Hydraulics
Old 01-31-2012, 12:57 AM
