928 park lights
I just picked up a 1982 928S...For some reason my driver-side park light and side marker light does not come on. All the other lights are fine, even the driver-side blinker works. Could they be wired together and a bad lamp breaks the circuit?
Any suggestions?
Old 02-17-2012, 11:48 AM
928-Electrics Guy
Alan in AZ's Avatar
If you mean rear side marker & rear marker - they are not in series (no bulbs are on your 928), but you may have a common grounding issue between these two - you need to evaluate the connections.
Alan
1994 928 GTS Black/Black Manual
Old 02-17-2012, 12:00 PM
Madman
Ok so first up, please tell me you checked the bulbs and the bulb connection points.
I dont know about the 928 but the 944 has separate power leads for the left and right park lights. My friend had a 944 for a while and a similar situation happened. I ended up diagnosing the light switch; which I disassembled and repaired. The reason the contact burned out was because someone added non OE taillights and powered them from the drivers side parkers = too much current draw through the switch.
I would check the downstream power leads for 12v when the lights are on. It could be a faulty connection- either in the switch or somewhere else.
1979 Porsche 928 3sp auto, black (gone)
Yamaha FZ6R, Raven Black. (gone)
1997 VW Jetta GLX VR6 swap in. black (gone)
1988 Jeep Cherokee 4.0 lifted, mudders, roll cage, black (wife's)
Old 02-18-2012, 03:42 AM
928-Electrics Guy
Alan in AZ's Avatar
Assuming the front markers work on that side - it is not the light switch.
Alan
Old 02-18-2012, 03:24 PM
Thanks guys...I found that the harness (panel where the fuses are also) didn't have a good connection. I still just ended up puttining th new bulbs in anyway (what a pain for the side markers!)
I did find out that the front park lights and the side markers ARE powered by the same wires. There is a 4-point connector with a jumper symbol on it.
Old 02-20-2012, 10:12 AM
