-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   I fabricated a kill switch for my 928 (http://forums.pelicanparts.com/porsche-928-technical-forum/655101-i-fabricated-kill-switch-my-928-a.html)
924CarreraGTP 02-01-2012 12:26 PM
Do you guys like my kill switch? Let me know your thoughts. This even conforms to the proper battery disconnection procedure. The only thing that doesn't completely satisfy me is that the secondary gound cable from the switch to the body is not copper. However, this system works great and has been 100% reliable for the past two three weeks. I thought I would share this.
http://forums.pelicanparts.com/uploa...1328127464.jpg
http://forums.pelicanparts.com/uploa...1328127527.jpg
http://forums.pelicanparts.com/uploa...1328127584.jpg
http://forums.pelicanparts.com/uploa...1328127621.jpg
dcrasta 02-01-2012 12:36 PM
Cant tell from the picture but is that wire sufficient ? Looks a little thin, but good idea..
Pete R 02-01-2012 12:46 PM
but why?
MPDano 02-01-2012 01:12 PM
Originally Posted by Pete R (Post 6530955)
but why?
I think because the ground cable should be a lot thicker (lower number Gauge). Your Ground cable looks about what I use on my Stereo amps.
Plexus928 02-01-2012 02:39 PM
A switch between the relay and the fuel pump is easier,smaller switch can be hidden anywhere close to the drivers seat. I use a gravity cut off switch from a bosch injection system , auto shut off if the car is in accident (or flips)
The reset button doubles as a security off switch.
MarkRobinson 02-01-2012 02:58 PM
ha ha, bought the switch yesterday, was gonna do the exact same thing tomorrow night. Funny. :)
MPDano 02-01-2012 03:24 PM
I still think it's a "Great" idea, but I personally would go with a larger gauge cable. We all know the ground issues we have on our 928's so why skimp on the ground that comes "directly" off the battery? It's the Main Bad Boy ;)
Smokin' Joe 02-01-2012 05:32 PM
Would it not be better to mount a kill switch where it can be reached by a seated driver? Unless you just want an easier way to disconnect the battery for when the car is sitting.
Pete R 02-01-2012 06:21 PM
lol, my bad, why the kill switch?
but your right, the cable is (appears) too small. He'll know if it starts smoking.
Danglerb 02-01-2012 07:00 PM
I was thinking the kill switch needed to be on the outside?
19psi 02-01-2012 07:07 PM
but why?
It would be a quick convenient way to cut power during maintenance but other than that I'm not sure.
MPDano 02-01-2012 07:56 PM
Great Anti-Theft Device :D
DougM 02-01-2012 08:50 PM
Who wants to steal a 928? Why would someone want to steal something that will cost them money? :)
Pete R 02-02-2012 05:11 AM
It's not worth resetting the radio and clock to use as a theft device, it's out of reach of the driver for any safety benefit, and if it's for maintence, how much is being done? It's not that hard to just unscrew the ground to begin with. While it's kinda neat I don't see any real purpose for it.
Luis_M 02-02-2012 09:03 AM
I had the same switch in my car for a while between the battery ground and the chassis, since I wasn't driving the car much and didn't want to run down the battery between uses. I put the switch in around 2007 and loved it while it lasted. But.... the switch failed this fall. Since it is sealed, no way to clean it so I had to replace it. Ironic that the "newest" electrical part on the car failed. No telling how long it was making lousy contact before failing, either.
I replaced it with a knife switch by Wirthco. Much more "reliable" in my opinion. Quite handy now that I'm doing work on the electrical system. Once I'm done, I may retire it, but for now, it's pretty useful.
My current switch is similar to this one and was about $20-25
http://forums.pelicanparts.com/uploa...1328201917.jpg
Danglerb 02-02-2012 09:49 AM
When I am "doing stuff" I find it easier to loosen the neg clamp on the battery and take it on and off instead of messing with the wingnut.
MPDano 02-02-2012 11:34 AM
Same here, my wingnut is tightened with channel locks and left alone.
these are the only type of Battery Disconnects I would trust since they are made by a company that makes proven race car stuff.
http://www.moroso.com/catalog/images/74100_part.jpg
http://www.moroso.com/catalog/images/74106_part.jpg
The boots to cover the connect part.
http://www.moroso.com/catalog/images/74110_part.jpg
Here's a quote of the cable gauge sizes:
Meets sanctioning body requirement that terminals on the master electrical cut-off switch be covered
Perfect compliment to Moroso Part Nos. 74100, 74101, 74102 and 74106
Prevents the shorting out of exposed terminals
When installed, creates a finished “clean look” to disconnect switch wiring
Constructed out of high quality, pliable, race environment friendly rubber
Accommodate 2 to 4 gauge wire and 1/2" to 3/8" terminal studs
Can be installed before or after termination of remote fitting ends
Two boots per package; one each Black/Red
Link to Morosso Battery Disconnects.
Moroso : Category Display
Pete R 02-02-2012 11:52 AM
I replaced my negative cable wingnut with a washer and allen bolt. I leave the allen right there in the tool area. I have to secure a couple large amp cables as well as the battery cable to it works for me
924CarreraGTP 02-02-2012 02:37 PM
Actually my car has draw thats dropping the battery. Big Surprise huh? Only, I've pulled tested the fuses and cannot isolate it. So this is what I did. I plan to get another stock ground strap and connect it to the body in a day or two. I agree that it's not a perfect set up yet.
MPDano 02-02-2012 02:45 PM
Aren't those fun. I remember my Brother fixing my electrical short in my 79 Seville back in the day. I remember him using a $2 tester light and he fixed it in 5 minutes. I probably should have been paying attention when he fixed it too. Automotive Electrical Troubleshooting is a Talent, that's for sure :D
