Driver side seat stuck
I moved my seat all the way up to vaccuum behind the seat and now it will not move at all. I tried changing the fuse and no luck. Is the motor dead? Could it be a pinched wire? Any suggestions please?
Old 03-10-2012, 12:29 PM
honerboys's Avatar
i think there should be a manual release under the seat - towards drivers door - looks like a tube pointing forward - move it towards the drivers side - should release - good luck
84 928 S - SOLD
2012 Cayenne S
Old 03-10-2012, 01:28 PM
I have same issue with passenger side. Have heard about the manual release but I think its model year specific. At least I have not found the tube on either seat in my '85 model. i have the drivers side seat out and with easy access could not find the release. Good luck with yours.
_
1985 Porsche 928S "USA" 5spd Black, Tan Interior
Old 03-10-2012, 02:08 PM
19psi's Avatar
The release isn't hidden or hard to get at. If your car has it, you can't miss it. My '82 has them.
George in Indiana
928 Weissach #153
Cayenne S
Old 03-10-2012, 02:32 PM
Pete R's Avatar
oh, that's it your done. You just have to sell the car to a short guy now.
I could be the switch, do you hear any noise or twitch when pressing the button. You also could have lodged something in the track. Did it attemp any reward motion at all?
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 03-10-2012, 03:05 PM
I have a 1988, does it have the release? I see a silver tube that looks like it can be wound, is that it?
Old 03-10-2012, 03:09 PM
1978 928 - 9288200072
Here is a picture of the underside of the seat so you can see where the release lever is. It is beside the right hand track, just above the electric motor. This level is used on the earlier models - I don`t know what year they changed.
This picture should help you figure out whether you have this lever or not.
Rick
1978 928 - 5 speed - no sunroof - Copper Brown Metallic - Cork Interior
Old 03-10-2012, 03:11 PM
I just totally killed myself, I have three 928's and I went to put the key in the ignition and realized I put the wrong 928 key into my 1988 928. Now it is stuck, I turned it halfway up to the start and now it won't go back down to the original position to come out. Any suggestions?
Old 03-10-2012, 03:12 PM
Rick are you referring to the long black tube next to the track on the right side of the picture
Old 03-10-2012, 03:15 PM
Yes that is the tube I am referring to. On my car (1978) you push that level toward the track to release the gear. It was quite sticky on my car and needed quite a bit of effort to move it.
I read somewhere that on newer 928`s there is a mechanism that you can wind manually and it turns the gear to move the seat back and forth.
Rick
Old 03-10-2012, 03:19 PM
Your problem with the seat could be the switch also. If the seat back moves, then the fuse and power to the seat are okay as there is only one power connection for each seat. In this case, the problem must be a bad switch, bad motor or pinched/disconnected wire. On mine there are three rocker switches on the seat - they are identical and therefore interchangeable. You could unscrew the switches on the side of the seat and try exchanging them.
Rick
Old 03-10-2012, 03:43 PM
There is no lever under the seat, I looked. There is a place where I can stick an allen key into but the teeth on the crank are broken so it is not letting the chair go back. What luck.
Old 03-10-2012, 07:44 PM
Network Native
Danglerb's Avatar
Which gear is bad, main drive to the rail, or just some emergency drive gear?
I would be looking at getting power to the motor if the main gear is OK, swap a switch as has been discussed.
If the main drive gear is bad, seat is going to need to come out, so I would do the back bolts and do whats needed to move it back once and get the fronts out.
BTW this thread really needs some pictures.
Old 03-10-2012, 10:58 PM
