-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Passenger window not working (http://forums.pelicanparts.com/porsche-928-technical-forum/664667-passenger-window-not-working.html)
shonwood 03-10-2012 04:50 PM
On my '82 928S my passenger window is not working. I have 11.7 volts at the connector ( red/brown). Is there any way I can jumper it out to test it or is the window motor itself bad. Driver-side works fine so it can't be a fuse or relay i'm assuming since they share the same one.
Any suggestions?
Danglerb 03-10-2012 04:55 PM
Measured how under what conditions?
What the battery measure?
Assuming you just put a digital meter on it, and the battery is something in the normal range around 12.5v you have a weak connection between that point and the battery. Check fuses etc. and ground points.
shonwood 03-10-2012 05:00 PM
I just turned the ignition where the radio comes on...it measured between 11.7 to 12.1 v. This should be enough for it to do something...you think?
honerboys 03-10-2012 05:07 PM
i'd suspect the switch is bad
shonwood 03-10-2012 05:18 PM
if the switch is possibly bad, how can you test it? the other two grey wire has to be a NO and NC correct?
garylewa 03-10-2012 05:34 PM
Jumper motor first using a 12VDC supply if it works (motor moves window up/down; obviously) the problem is probably in the switch. It's a rocker switch; I wouldn't waste time trying to rebuild these; just purchase a new one.
What dangler stated above is also true; if the motor works off your 12VDC supply but won't work off of the cars voltage do what he is saying
Danglerb 03-10-2012 05:57 PM
The catch is a typical meter measures voltage with no load.
A digital meter often has like a million ohms of resistance on the input exactly so it doesn't place a load on a circuit that may be made of other devices with high impedance and low current capacity. A cars electrical system is the opposite in most cases like your window motor it needs AMPS of current to work.
Lets take an guess that it uses 6 amps to run normally, this means it has something like a 2 ohm internal resistance.
Now imagine what happens if you have a dirty connection with say 600 ohms of resistance, the voltage the motor "sees" is 12v x (2/(600+2)) = nothing.
Measured with the meter though you get, 12v x (1000000/(1000000+600)) and that is pretty much 12v.
shonwood 03-10-2012 06:33 PM
So other than having a separate 12v power supply, there's no way to bypass the window switch?
924CarreraGTP 03-10-2012 07:20 PM
The window switch plugs into a two prong plug behind the console side skirt. You could possibly jump the switch terminals there. If it works, replace the window switch with a good used one (I have one). Though I think you will find it will turn out to be the motor. A lot of window motors go out on that side. I'm not sure why. Possibly different amounts of stress on that side compared to the other. The switches are troublesome though too. Sometimes they can be fixed.
shonwood 03-10-2012 07:35 PM
I pulled the panel apart and it seems to be a bad regulator (motor). When I push the button I hear a slight click coming from the motor. So it appears it may be bad. They seem fairly easy to replace (2 wires and 2 screws) that hold it in place. I'll order one and see what happens.
Thanks for all the helpful troubleshooting tips! This is a great sight for help.
Mrmerlin 03-10-2012 08:35 PM
ahh you can remove the motor and take it apart,and clean it
and then it will probably work they get gummed up.
also lube the pivot on the window arm this gets sticky then overloads the motor this then overloads the window switch
Danglerb 03-10-2012 11:08 PM
One of these?
R Window Motor 78-83, 8 teeth 928 624 014 04 $295.00
I would test it directly with 12v and/or clean it first.
garylewa 03-11-2012 08:33 AM
You can't be 100% sure the motor is dead until you put at least 12VDC to it. Are you sure you are getting the proper output voltage to this motor???
Sometimes DC as well AC motors "hum" until they hit pull-in voltages. Check to make sure you have 12VDC at the motor.
JGoatley 03-11-2012 05:13 PM
I agree with merlin. I had the same issue 2 weeks ago. Took the motor apart and cleaned all the grease off the brushes and coil. Works like new now.
Dean_Fuller 03-12-2012 07:56 AM
You can swap the switch to the other door and see if it works.
shonwood 03-12-2012 05:48 PM
yup...I pulled the window motor and it's dead. I even hooked it up to the battery directly. Now when I I buy a new one, it's remembering where all the screw go. LOL
Thanks for the insight guys!
Danglerb 03-12-2012 08:51 PM
Its good to take pictures as you remove stuff and use a marker and zip lock bags.
924CarreraGTP 03-12-2012 09:19 PM
As someone said above it might be frozen and you can disassemble it to try to fix it. I can sell you a used one if you want. Send me a pm if you're interested.
shonwood 03-13-2012 08:06 AM
I took it apart GTP and all f the mechanical parts were free but when I put 12v to it, nothing happened. I think I may have found one locally.
Thanks!
dcrasta 03-13-2012 11:13 AM
This:
I had a motor that would stop, and I would 'fonzie' it up (hit the door). Sprayed some Deoxit in the brushes and it works great. Also check for corrosion on the connector to the motor (may want to do that first) . Corrosion increases resistance in the circuit, and causes voltage drops.
MPDano 03-13-2012 01:40 PM
Originally Posted by dcrasta (Post 6620533)
This:
You do realize that there will be some that will have no idea what "fonzie" means, don't you? Here's a Pic to understand for you young whippersnappers ;)
http://img2.moonbuggy.org/imgstore/t...-dream-rod.jpg
http://www.sitcomsonline.com/fonziscoolbutton.jpg
924CarreraGTP 03-14-2012 12:33 AM
So would you go as far as to say that he needs to winkler it up a little bit and then see if it works? If that doesn't work he could try to henry it? As long as he doesn't roger it we'll be okay. Roger: english slang for buggering ;)
dcrasta 03-14-2012 11:07 PM
It was all over once I jumped the Shark..
tychain99 03-15-2012 04:00 PM
I have a motor if that ends up being the problem. My window broke and I needed the little plastic disc off the control arm. Mine decayed and fell apart causing the window to fall into the door. I bought a whole assembly, and did not use the motor. The plastic clip is riveted in and the purchase was useless . I had my brother make a replica out of metal, and tack welded it on to my arm, and it works fine.. long story for no reason, but I have a motor collecting dust.
