harborman's Avatar
Washer tank leaks
Seems my window washer tank has a leak, the one next to the coolant fill. It's been that way since I got the car. Before it held some fluid but now it pisses out below the fender. Has anyone replaced/fixed that tank? Seems maybe the fender well has to be removed to get to it. Really hard to see in there.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 03-27-2012, 11:44 AM
Pete R's Avatar
There's a motor and a hose underneath, most likely culprit. It's actually pretty easy to get out. Pull wheel then the fender panel. There's just a strap that holds it in. Getting the old hoses and electrical wires is kind of a pia but not terrible
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 03-27-2012, 11:55 AM
harborman's Avatar
Ok Great! Thanks for the info. I will get around to it pretty soon as it seems to be getting worse. I rarely drive the car in the rain but sometimes one needs the washer to work. Previous owner must have let it freeze, but the car sat for years.
1986 928S
32 valve engine
Old 03-27-2012, 12:55 PM
Pete R's Avatar
not necessarily, the motor is right at the bottom of the tank and that has a seal, then there are hoses on the output that could be dry and cracked too.
btw. try the orange rain x wiper fluid.. awesome, hardly even need wipers once the windshield is coated.
Neon SRT4 track car
Old 03-27-2012, 04:03 PM
curtisr
curtisr's Avatar
btw. try the orange rain x wiper fluid.. awesome, hardly even need wipers once the windshield is coated.[/QUOTE]
Roger that.
Old 03-27-2012, 07:21 PM
harborman's Avatar
Roger that.[/QUOTE]
Yes, I have the Rain X, comes in orange and green. But now I need to fix the leak. The motor works, but fluid drains right out.
1986 928S
32 valve engine
Old 03-28-2012, 05:15 AM
harborman's Avatar
As it turned out, the leak was at the fill tube where it comes into the wheel well.
Since it only leaks when filling, I put some RTV sealant around the leak area. I first cleaned it with denatured alcohol.
I tried to get a nice clean bead around it but the RTV would not cooperate and besides, it will be hidden with the fender liner.
1986 928S
32 valve engine
Old 03-29-2012, 10:57 AM
harborman's Avatar
One more picture of the washer tank.
1986 928S
32 valve engine
Old 03-29-2012, 11:06 AM
