-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   High perf. tires, without tramlining. (http://forums.pelicanparts.com/porsche-928-technical-forum/669543-high-perf-tires-without-tramlining.html)
mikeesik 04-03-2012 02:46 PM
Looking for a set of tires not too soft and noisy.
Had problems in the past with the car following longitude ruts. HATE IT !!!
Have Cup 1's on the car with 225-45-17-/-255-4o-17 rear.
Anyone have tires with which you are satisfied about and never think of them when your driving?
toofast928 04-03-2012 02:58 PM
I have the Continental DW. 17" wheel, no tramming ride is perfect.
mikeesik 04-03-2012 03:01 PM
What of road noise-wear-and in the wet?
Thanks for replying btw.
stepson 04-03-2012 03:06 PM
Mikesik,
Are these original stock Cup 1's? If not, check the offsets. I thought that tramlining was normally not a tire issue, but rather a wheel issue.
Pete R 04-03-2012 03:10 PM
Bridgestone re760's.. awesome
Danglerb 04-03-2012 03:19 PM
I'm think Kumho V700 or Hoosiers, hate that tramline with grooved pavement, but avoid patterns with straight lines.
mikeesik 04-03-2012 03:24 PM
Is that a fact?
mikeesik 04-03-2012 03:28 PM
Originally Posted by stepson (Post 6665210)
Mikesik,
No stepson, they're after market.
Thought that they'd be copies; at least of course in the offset department.
Is this from your experience? Thanks for the thought.
hss1960 04-03-2012 05:52 PM
Put in some Delrin rack bushings, they'll make a big difference and greatly reduce trammlining.
laneyamps 04-03-2012 08:11 PM
I currently have Kumho Ecsta's on mine ...No issues to speak of...All I can say is that (for the last 3yrs) I've been very happy with them
Danglerb 04-03-2012 10:20 PM
Originally Posted by mikeesik (Post 6665239)
Is that a fact?
I had a set of Dunlops with the straight grooves, terrible.
19psi 04-04-2012 07:21 AM
I really like my Hankook Evo V12 tires. They've never gotten squirrely under any kind of road conditions and Indiana can have some really sucky roads come spring time. On black asphalt they are silent but on lighter color aged highways and concrete bridges they can get rather loud. My 928 is one of those cars I can let go of the steering wheel without fear of it darting from grooves or ruts.
I'm running 235/35-19 up front and 265/30-19 rear. Not very expensive either at less than $250 each.
stepson 04-04-2012 08:19 AM
No personal experience, I run stock Porsche wheels with correct offsets. Just passing on others' experiences.
Pete R 04-04-2012 08:28 AM
that's funny.
Alan in AZ 04-04-2012 12:51 PM
It is motre likely to be the wheels (offsets) than tires, though wider section tires may also have an effect as will badly worn tires if the alignment is off (e.g. unevenly worn on the inside or outside).
I'd check the wheel offsets compared to stock.
Wheel offsets on aftermarket are all over the place - and were very different for 928, 911 etc
Alan
dcrasta 04-04-2012 04:16 PM
928 front offset is 65 ET- IF you are using aftermarket wheels with 59ET or less you car will be more sensitive to Tramming .
Also your alignment (front and rear) can have adverse effects, and if your ride height is lower than stock, you could be introducing excessive rear camber (negative).
If you have the option try a set of factory wheels. If not, get your ride height and alignment checked.
