mikeesik's Avatar
Flaring your fenders-not crimping lip.
I thought rolling your fenders justified a look like flares.
Perhaps I was wrong and what I really meant was flaring fenders.
Anyone know how?
Formerly from ratslist.
AMG E 55..2002.
Lotus Esprit SE. 1990
Old 04-11-2012, 07:54 PM
JK McDonald's Avatar
Basket Ball -
Hey Mikeesik, I think most people understood what you were trying to do. I'm sure it can be done, it's just from what I have seen, the final result of several attempts by others at reshaping the wheel openings on a 928 did not turn out very well.
I might add that I have been successful in removing accident damage from fenders that were already flared. In several cases while working on a couple of 930’s, I used a deflated basket ball in between the tire and fender to initially get the original shape back. You simply move the ball around and carefully add air from the output of a regulated compressor line. For what it’s worth, perhaps this might work on a 928.
Good Luck, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 04-12-2012, 05:48 PM
Originally Posted by JK McDonald View Post
In several cases while working on a couple of 930’s, I used a deflated basket ball in between the tire and fender to initially get the original shape back. You simply move the ball around and carefully add air from the output of a regulated compressor line. For what it’s worth, perhaps this might work on a 928.Good Luck, Michael
Great idea, not about to try it, but can't see why it would not work.
Old 04-12-2012, 08:25 PM
DanielDudley's Avatar
Rolling your fenders flattens the inner lip, and can push out the fender only slightly. The only way I have seen people flair a 928 rear quarter is by cutting and shaping it, then welding pie shaped sections into the cuts. Most have been reshaped to resemble a GTS flair.
I think Louis Ott made some add on flairs years ago. He may still.
Old 04-17-2012, 06:51 PM
