nuts4porsche's Avatar
engine swap advice
will my 80' 4.5 US auto motor swap out into a 81' auto? will all the wiring work or do i need to swap out computers and all? please help,so i dont make a mistake in purchasing a car that it wont work in. thanks all!
80 US auto
Old 05-02-2012, 06:16 AM
Pete R's Avatar
I'm not sure what intake system these two are on, but the easiest way is to use the long block from the new engine and bolt on the intake and controls that is currently in the car.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 05-02-2012, 09:21 AM
i was going to swap the whole motor for motor,the motor in the 81' is shot and maybe rebuildable,but thought a complete swap would be faster/easier and more affordable than tryn to fix bad motor.
80 US auto
Old 05-02-2012, 09:26 AM
if both are L-jet, you should be ok, but from what i recall, the 81 AFM superceeds the 80, so try that first.
My Car:
84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!)
Old 05-02-2012, 11:48 AM
sorry im new-whats the AFM?
80 US auto
Old 05-02-2012, 11:50 AM
air flow meter, the little flappy door piece that fits between the throttle body and the air filter box for the intake. are both of these engines complete assemblies or is it just like a lower end for your replacement?
My Car:
Old 05-02-2012, 12:07 PM
Network Native
Danglerb's Avatar
Both same basic Ljet, so guessing easy swap. I would look both motors over carefully on the stand and move anything that looks like it needs moving. Good time to take care of anything else the motor might need, gaskets, vacuum lines, etc. as well as freshen up the engine bay while the motor is out.
Old 05-02-2012, 01:51 PM
both are complete,but mine runs. the 81' has everything already done to it,so i was going to take all the good working items off his and put on mine for a good runner. sounds like i should have an easy swap. thanks guys, just needed that info so i didnt do something stupid and be divorced in a week. lol
80 US auto
Old 05-02-2012, 02:14 PM
Pete R's Avatar
we should say "as easy as a swap gets" not "easy swap" Do all the gaskets while it's on a stand if you can. It will never be easier. You'll so regret not doing it if something leaks.
funny, when I did something stupid I ended up married
Neon SRT4 track car
Old 05-02-2012, 06:32 PM
