DannyBNH's Avatar
Hose to Aux Air Regulator
My idle was screwed up after doing the fuel lines and i was going to spray out the AAR because it might be sticking. When I started to take off the rear hose attached to the regulator the end started to crumble so I want to replace it.
This is the little short straight one 3 or 4 inches long that faces the rear of the motor, not the curved one. The part is 999 239 09 40.
Do I need to order from one of the 928 sites (30 bucks) or will a "Part Store" hose (< 5 bucks) work.
I have a crimp forming in one of the lines and need to replace it with a longer one so while I'm in there might as weell fix that as well.
Is there anything special about the hose?
-Dan
1979 Porsche 911 Black on Black widebody 3.2 - SOLD
2015 Jeep Wrangler Sport Unlimited - White
1984 Porsche 928s Black on Black - SOLD
Old 05-08-2012, 04:02 PM
Kyle C
Don't think there is anything too special about it. I replaced mine with a length of fuel vapor hose.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 05-09-2012, 06:04 AM
1979 5sp 928 project
as long as it's not too susceptible to suction it will be ok. I tried to use a softer hose for mine and it sucked it closed...
1979 928 5sp project
1984 928S 5sp black on black
Old 05-09-2012, 10:13 PM
DannyBNH's Avatar
I ended up ordering 1 from Roger @928srus. Better safe than sorry.
Old 05-10-2012, 03:25 AM
Network Native
Danglerb's Avatar
You can buy vacuum hoses in larger sizes, but regular hose does not work.
Old 05-10-2012, 10:06 AM
