-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   timing belt 4/7 how do it? (http://forums.pelicanparts.com/porsche-928-technical-forum/678351-timing-belt-4-7-how-do.html)
roverl322 05-16-2012 07:38 PM
i was looking for 2 days in internet a dyi page or a document with pictures and info how replace timing belt 928s 4.7 . and what especial tools to buy to do it ? cause i will antent it myself not mechanical experince but alto tools patient and many extra time? I only found a coupe pages with s4 precedure in rennlist???
anu help with nice easy diy write out on older 928 belts??? thanks
mikeesik 05-16-2012 08:02 PM
Hi. Go to -'BIG DAVES 928 PAGE.'
I suppose this can help you, pics. and all.
924CarreraGTP 05-17-2012 01:54 AM
Big dave's 928 is an '85 5.0 liter 928. They are simular enough but the 4.7 is a little bit easier.
Roverl322, It's basically the same as the 32 valve only you don't have to pull twin distributors off of the front of the engine. The 4.7's distributor is on top of the motor and out of the way. It's a little bit more simple, but tensioning and making sure the engine is in time is pretty much the same.
Linderpat 05-17-2012 06:04 AM
Here you go: SharkSkin - Shark Attack Round Twenty-Seven - Timing Belt/Water Pump
