car wont start after one week
Hi Guys,
After approximately one week of not driving the car, the starting can be very strange. When I turn the ignition key, the starter works just fine but the engine doesnt show any signs of starting.
I found out that if I charge my battery completely and give a starter of about 10 seconds while the gas pedal is fully pressed to the floor the engine will start and will be a bit flooded for some seconds - so the idle will not be stable and after a few seconds it will stabilize.
I Checked the electricity and there is no problem, the fuel pump seems to be fine as well although I cant tell if the fuel reaches the engine...
My prime suspect is the fuel accumulator...what do you think?
Thanks!
Porsche 928S 4.7L 1980 European redhead
Old 05-22-2012, 12:32 AM
MPDano's Avatar
I thought accumulator is hard start hot not cold.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-22-2012, 03:39 AM
Well, I think it use for both since the aim of it is to keep the fuel pressure in the system...
Old 05-22-2012, 12:34 PM
Engineer of profanity
924CarreraGTP's Avatar
Thermo time switch? Cold start injector? Clean the connectors, and test them. So the car is running but hard to start after a week? Try to just bump over the starter one time and then let off of it. Then try to start it normally. Repeat this and see if it starts better. My '83 had an odd cold start problem after a week and I cleaned the connectors to the thermo time switch and the cold start injector and it starts right up every time now. Those parts can go bad and make the car not start.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 05-22-2012, 01:33 PM
Not to be a hijacker, but my '81 has started exhibiting a similar behavior. Where abouts are those thermo time connectors? I'd like to hit those when I do some grounds cleaning in the near future. Thanks!
Old 05-22-2012, 10:17 PM
Can you please tell me where are the thermo time switch and the cold start injector?
I will clean them and see if it will make any difference.
Old 05-22-2012, 11:16 PM
RE: cold start problem
Scroll down this and theres a good picture of the 4.7 liter thermo time switch.
Old 05-24-2012, 03:48 PM
Great info thank you
-Colin-
'81 928 Palisandermetallic auto
Old 05-24-2012, 05:06 PM
Thermo-Time Switch Questions?
Scroll down to Landseer's post for the location of the cold start valve.
Old 05-24-2012, 05:46 PM
