Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 928 Technical Forum
928 1983 door panel remove help
Hi there i note a weird noise when window is up or down , maybe regulator ar a piece loose ther,, i need to remove door Panel , BUT KIND WORRY to do it without instructions my panels are like new and do not want to brake anyparts I have old style panels with speakers hide and little holes any help or guide or point in other post thanks
Old 06-02-2012, 05:30 PM
mikeesik's Avatar
Hi.
You do NOT have to remove the whole door panel.
There is a small phillips screw holding the knuckle guard behind your door handle.
Remove that and you can lift the door-middle insert- to inspect. You can lift it up gently.
Formerly from ratslist.
AMG E 55..2002.
Lotus Esprit SE. 1990
Old 06-02-2012, 07:43 PM
mikeesik's Avatar
Funny-I was thinking about this today!- My 2 windows are a bit flappy / loose in mid raise.
I figure like my other car I would remove the door inserts and tighten the plastic guides with an allen wrench.
All 928's eventually have this problem.
AMG E 55..2002.
Old 06-02-2012, 07:50 PM
Pete R's Avatar
Just pull wicked hard, it will unsnap.. KIDDING.
remove the plastic plate behind the door handle (phillips screw)
remove the center decorative panel (the bottom has tabs. The top has panel fasteners inbedded that need to be pulled out from their receptical. then it can be lifted up.
remove the arm rest. pretty sure there are 5 bolts. 2 in the pocket,2 under the center panel, and one in the front in the air inlet to door. You may have to undo you switches when you do this too
remove the center of the door locking knob.(pry out) unbolt the knob, unscrew the plastic piece behind the knob.
The panel is held on with fasteners like the center piece, work you way around and pull them out.
It may be a good idea to buy a tool to pluck out the fasteners. if you rely only on the panel to pull them out sometime the rip out of the panel and not the door. There may be some other things I forgot off the top of my head but that's most of it
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 06-02-2012, 07:58 PM
Petie3rd
Mrmerlin's Avatar
to follow on remove the 2 screws on the harness plate sheath cover at the front edge of the door panel
and their may be a few screws along the bottom edge of the door panel.
You can replace the 2 plastic window guides they are pretty cheap but will restore a solid window function.
Use a shower curtain plastic and Weldwood brush on adhesive to recover the door prior to installing the door panel,
the dollar store sells great clear curtains for this job, yep they cost 1.00
^^^ Stan ^^^ 2011 BMW K1300S Magma red
1988 S4 5 sp, Black / Black leather/ Carmel carpet
Old 06-03-2012, 04:35 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
