Kool
Clutch line
I have a '78...
In a couple months, after the shop is built, I am going to replace the Master, Slave, and blue hose. (I have all the parts) Got a hard line that goes from clutch slave to a bracket on side of bell housing...from there it turns rubber, and goes to clutch master....There is a bad "twist" in the line where it connects to the slave. I want to replace this line. Does anyone know if there is a replacement available from any of the vendors, or even Flea-Bay, that will replace that entire line, with (1) rubber/flexible hose? Thought I would ask before I go looking...lol Thanks in advance!
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
I know there is not one line to replace both. I think you are saying that the metal line has a nasty twist to it. Correct?
IIRC, that line is only like $30, as I replaced a missing one a while back. But I have slept since then and I have CRS.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Kool
thanks stepson....I thought, between all the 928 forums and threads, that I had read where someone replaced the entire rig with (1) hose....perhaps they had it made....yes..mine has a nasty twist right at the fitting on the slave. I just happened to notice when I dropped the starter for testing a month ago or so....Since my master is leaking, I decided to replace the master, slave, blue, and connecting line, which is the last piece I need...I believe the rubber hose is a failure point as well...I wonder if I pull the fittings, if a hydraulic shop could make up a single hose for me? Would it hurt anything? I think not...
Petie3rd
Greg Brown at Precision motorworks in Anaheim sells new hoses that will last the life of the car, do some searching
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Kool
that might be where I saw it before...thanks merlin!
