86.5 engine dies while driving
Starts up easy and idles good but will die suddenly without any warning while driving. When it dies it starts right up again and i'll drive for while and it dies again.
Fuel pump and fuel filter are good (both new). Fuel injectors good (replaced by previous owner). I'm thinking it's electrical. What should I check besides relays?
Old 06-16-2012, 04:51 PM
Network Native
Danglerb's Avatar
Relay, relay, relay, fuse, ign switch, short in the fuel injection wiring.
Could be fuel or spark, but dies suddenly and immediately restarts, but guessing not without cycling the ignition key off and on? Or will it die going down the road and catch again and keep running?
Old 06-16-2012, 06:49 PM
newold928's Avatar
Mine doe's exactly that.
Old 06-16-2012, 07:20 PM
No, it doesn't start up again by itself, I have to turn the ignition key off and on again.
Old 06-16-2012, 07:34 PM
Network Native
Danglerb's Avatar
Makes me suspect something happens due to cycling the ignition switch, not something random. Relay, or switch top my list.
Old 06-16-2012, 09:05 PM
European Shark
riber.bentsen's Avatar
Sounds a lot like a worn-out ignition switch...
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 06-17-2012, 06:22 AM
intermittant running
The green wire carrying the hall signal can cause this.For some reason mine would hold a constant charge. This affected the fuel delivery or spark or both. The charge would disipate almost immediately at first and then the car would start and run until either hot or I turned it off and then would not start when hot. This time to restart got longer and longer so I traced it to the wire and found that if I ground it for an instant it would start. Because it was too intermittant and difficult to reach the distributor (not a 928)I finally just added a wire that poked out near the headlight.If the car did not start I got out and touched the stripped end of the wire to the headlight chrome.A small spark jumped and I was then able to start the engine. It was a fun car but......Lancia Beta 2000
Old 06-17-2012, 07:56 PM
Network Native
Danglerb's Avatar
86 will have cps instead of green wire, but those are usually random flaky, not key off and always restarts.
CPS crank position sensor.
Old 06-18-2012, 03:28 AM
Ignition Switch
Had a similar problem some time ago with an 86 1/2, was the ignition switch. Should also mention had a similar problem with a 1980, and it was a relay.
Old 06-18-2012, 11:27 AM
newold928's Avatar
today i put a new connector on the green wire. The old one was broken still the same i noticed when it gets warm it starts acting up sound's like the ignition module in side the dizzy any other thought's. with the car running i get 7.8v to the coil?
Old 06-18-2012, 01:34 PM
