newold928's Avatar
Car cut's out
1979 ROW 928 auto I was just driving along and the car quite and then started again??? WTF? Did this several times yesterday6/15/12 and to day. she will quit and starts right up anybody have an idea mechanical injection Checked the Dizzy and i have good vac i checked it at the booster with a gauge about 12 #
Old 06-16-2012, 03:54 PM
bad fuel pump.
defective fuel pump or injector relay.
G-Man
1984 928S Black/black 77,000mi
1986 944 NA w/ S2 front valence Black/black 91,000mi
1970 911T 49,000mi SOLD
Old 06-16-2012, 04:36 PM
newold928's Avatar
Injector relay on a mechanical injection? i swapped the fuel pump relay.
Old 06-16-2012, 04:55 PM
Sounds like the pump to me, after ruling out primary grounds.
My Car:
84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!)
Old 06-16-2012, 05:46 PM
Network Native
Danglerb's Avatar
Do you hear the fuel pump doing or not doing anything?
Mechanical injection I don't think dies suddenly from fuel pump, but sputters out as fuel pressure drops. I would suspect ignition issues, start with the relay, fuse, swap out the coil if you have a good spare.
Old 06-16-2012, 07:54 PM
newold928's Avatar
Yes i noticed the coil wire was a little Burnt i changed that wire and got the same results. When i got the vehicle i put a new ignition switch in (the old one was Shorting out) i will swap the starter relay. I have a MSD Master Blaster coil i can put on. any other thoughts will be greatly appreciated
Old 06-16-2012, 08:17 PM
