-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Rear window wiper (http://forums.pelicanparts.com/porsche-928-technical-forum/684881-rear-window-wiper.html)
camo 06-21-2012 02:37 PM
Rear window wiper
So my rear window wiper doesnt work and we figured out how to fix it but we cant get the wiper off! Its probaqbly something simple :) but how do you get it off?
924CarreraGTP 06-21-2012 03:06 PM
Two covers flip up from the wiper arm base and then two bolts hold the wipers on. You might need to fold it up and then pry it off after the bolts are off. Mind the spoiler and rear window though.
camo 06-21-2012 03:27 PM
I still couldnt figure it out.. :/ Is it different for mine maybe? Its a '82
Thanks for your reply though :)
tychain99 06-21-2012 03:59 PM
def not different... on the base of the wiper arms there is a black plastic cover that is riveted in place, the rivet acts as a hinge, lift the one end and it should lift toward the front of the car. might be stuck, but they def lift, and there are two nuts, each a diff size. make sure when you put the arms back on they are seated all the way or that little gear will strip out.
lfausty 06-21-2012 07:43 PM
wiper blade to replace a pin is going to come completely out to remove the blade from arm.
if taking whole wiper arm off from base , stated above.
blade cartridge? or whole wiper from base?
