Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
DannyBNH's Avatar
Tranny vacuum leak
I was looking to hopefully replace the vacuum hose that runs from the modulator on the transmission to the hard line that connects to the front/top of the motor.
My shifting is harsh (choppy) between all gears, so It seems to fit the profile of a potential "vacuum leak". I don't have a mightyvac but the hose was cheap so I figured I'd just replace it and see if it was the problem. When I followed the hose from the transmission, it goes to the top of the torque tube then I can't see it anymore. I've read a bunch of threads on Rennlist but I don't know if there is a difference between model years.
On my 84, the hard line goes from the top/front of the motor, runs along the passenger side fuel rail and down the back of the motor. Does the same hard line run all the way down the top of torque tube?
Where does the hard line end/hose begin?
-Dan
1979 Porsche 911 Widebody 3.2
1984 Porsche 928s Black on Black ( Daily Driver )
2003 Dodge Dakota 4x4 - For transporting parts.
Old 06-21-2012, 05:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
stepson's Avatar
Dan,
On my '89, I had the same symptoms. I found a thread on RL that gave me some really good hints. Basically, the hard line runs the length of the torque tube. I found that on my '89, I could remove the small triangular heat shield at the front on either side (I removed the passenger side)and use a piece of stiff wire with a hook to "hook" the hard line and pull over so I could see it. I then ran my hands from the end of the hard line to the clip that secures it to the torque tube and unclipped it. This gave me enough maneuverability to slide the new vacuum line from the engine on. I re-clipped it back to secure it and replaced the heat shield. I removed the extra vacuum line from up top.
YMMV.
Good Luck.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 06-21-2012, 06:05 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Formerly from Bannlist
MPDano's Avatar
Look at post #430, your culprit will be this hose and/or the one near the tranny fluid reservoir.
$900 1983 US 928S The latest LEO928S
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior
Porsche928Forums.com (NOW Mobile Enabled!)
Old 06-21-2012, 06:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
DannyBNH's Avatar
just finished doing both vac lines. The one above the Cat and the one in the back that goes from the modulator to the top of the Torque tube.
It still engages a little harsh, but seems a little better. It seems to be smooth when the car is cold. When it warms up it gets a little harsher. I'm starting to think something under the hood ( rubber ) is cause. I ended up buying a vacuum tester to see if I can find it
Old 06-22-2012, 11:19 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
DannyBNH's Avatar
A week later and I'm pretty sure my shifting hasn't really improved. It's still harse
after replacing the line from the modulator to the metal line on top of the torque tube and the short one above the cat.
Where do I want to vac test from.. The modulator or somewhere under the hood ?
I probably didn't mention this but it also shifts very early.. Like I'm in 4th at 40 mph.
-Dan
Old 06-30-2012, 05:09 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Maleficio's Avatar
Replace your fluid.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 07-03-2012, 05:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
