-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   confused on correct fluids (http://forums.pelicanparts.com/porsche-928-technical-forum/685451-confused-correct-fluids.html)
BoiseShark 06-24-2012 07:31 PM
I remember an old post on prefered oil but could not find it again.
I would like to know what everyone recomends for
A) Engine oil
B) Manual transmission oil (not sure if atf or 75/90 gear oil
C) any other fluids that are better than the rest.
I just read that Dano recommended the Zerex G-05 antifreeze.
I'm putting together a list so thats ize never forget.
I have a 79 stick
also how the heck you fill up the tranny. I want to replace all fluids before I drive much more.
Thanks for your help
Pete R 06-25-2012 05:17 AM
oh boy..
Just use the correct weight oil. If it has ZDDP even better.
The tranny oil is a gear oil. It will differ slightly if you have a limited slip or not. I like to use synthetic because it helps with cold shifting.
AirtekHVAC 06-25-2012 07:24 AM
LoL...an age old loaded question. Everyone has an opinion or preference.. lots of good info comes out of it. (I asked the same question a few months ago)...so far, I have decided on 20w50 for the engine...and that's as far as I got before I had to stop work and move.
Good luck...I too am trying to iron it out.. :)
kelanel 06-25-2012 10:06 AM
If you are running dino oil currently, you might as well stick with it, there are some good options. I dont know too much on the synthetics, but zddp is needed for wear prevention. i use Valvoline VR1 Racing oil 20w-50. it advertises a high ammount of ZDDP in it and does the job for me and easy to find at any autozone or napa/orielly usually.
