Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
metr0p0lis1927's Avatar
Pressure Damper problem??
while replacing cracked vacuum hoses in my engine bay I pulled the vac line off the fuel pressure damper and when I did, I noticed it was wet , not the damper itself , the vacuum hose. As in it was wet with gasoline, so I blew it out (the damper which was apparently full) and reattached the hose and started the car for a few minutes, then shut it off and checked the damper again which was once again full of fuel .
my questions are :
1) is this normal?
2) if not , does this mean that the internal diaphragm is shot and I need to replace the damper ?
3) is this dangerous?
1984 928S either Metallic Pewter or Quartz Gray
Old 06-24-2012, 10:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
1. no
2. yes
3. possibly, you will suffer performance wise as well as emissions.
My Car:
84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!)
Old 06-24-2012, 10:23 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Sounds like a bad damper diaphragm to me, but the best way to test itis to use a hand operated vacuum pump and attach it to the damper. If it holds a vacuum it should be okay, nut if the vacuum bleeds off, it's time for a new one.
Old 06-25-2012, 05:41 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
