Graphic engine images: what's missing?
Okay what's wrong with this picture. I'm trying to put this back together but with the baby and the actual full time job I'm very sleep deprived. Do you see anything missing or any issues whatsover? Any parts I should replace now from what you see? Thanks
http://forums.pelicanparts.com/uploa...1340687781.jpg |
Did you use any kind of assembly lube?
This is a real can of worms! Was it put together properly? What was done and was the person qualified? What was wrong initially?
That crank pulley looks like it was put on backwards to me. Is that even possible? Anyone else?
Good catch, Fabio. |
1. Your chain tensioner oil supply line on the one head shot is not installed yet.
2. The main "vacuum line" on the bottom of the TB is not present on the front picture: this is the large line that eventually goes to the brake booster & intake manifold side plenum (driver's side). 3. One of the far right water pump bolts is actually about 3" long as the bolt holds the plastic cover over the water pump: test fit that. 4. Numbers on the crank pulley are read from looking at the front of the engine: if read from the windshield side, that's incorrect. |
Pour oil over all the cam lobes/lifters and turn over once, then do it again before you install the valve covers: a good preventative maintenance item since it'll be a dry startup.
I dont see the timing belt tensioner.. Am I just being blind?
Intersting: it isn't there, but the Air pump bracket that's part of the tensioner housing is: might need more photos on this part...hmm.
I do not think that is the AP bracket but the AC bracket - needs a PKensioner 8>)
The ac bracket is there, the tensioner/air pump bracket is mia
So far it sounds like, take it apart, put it back together slowly checking everything.
| All times are GMT -8. The time now is 05:05 PM. |
