Dist mark tdc
if the crank and cam marks ar lined up where should the timing mark be.
i took a pic of mine and looking to see if its correcthttp://forums.pelicanparts.com/uploa...1342904463.jpg http://forums.pelicanparts.com/uploa...1342904488.jpg |
John,
IIRC, I believe there is a mark on the edge of the distributor to which the rotor should point. It's like a slight cut as you look straight down at the distributor with the cap and wires out of the way. |
| All times are GMT -8. The time now is 09:09 AM. |
